Found HDR-HC1 HD VIDEO CLIP
I can't play this. Can someone check it and comment, please.
Radek |
Sadly, the 66MB video clip was only 853x480. I would really like to see the full resolution. I just noticed that the links in the original post have changed from two .MPG files (8MB and 66MB) to a single .WMV file (86MB). I'll comment further on the 86MB version when it finished its download. -Mike |
No HD in the "test" files ...
Here is what PVA Strumentro diagnosed on the "original" .mpg files
They do NOT look at all original, but look like SD recorded in MPG !! And indeed they did not look that great...but colors looked ok ? in spite of ONE CMOS ?? Found 1 video stream. Found 1 MPEG audio stream. VIDEO #1 Resolution 720 x 480 Aspect ratio is 16:9 Frame rate 29.97 fps Nominal bitrate 7620000 bps First PTS: 00:00:00.900 MPEG AUDIO #1 MPEG1, Layer 2 stereo, sampled at 48.0 kHz. Bitrate 256 kbps Each frame contains 24.0 ms audio (768 bytes) First PTS: 00:00:00.900 |
This sample offers a 1440x1080 resolution (84MB).
http://www.watch.impress.co.jp/av/d...15/samp1_hd.wmv You should "save the target as" because it's a looooong download, but's it's impressive even if it's not as beautifull as the FX1's samples. |
I have plenty of other clips, from FX1, that display 1440x1080. Why is this one only 1280x720 on screen? Edit: Upon further inspection, it looks like the clip is letterboxed. I cannot expand the width because I am limited by the height. What a pain. |
Hi all.
It looks like videos were post-processed (in WMV Encoder?) by unsqueezing to 1920x1080, then deinterlaced (or maybe they were shoot allready in CineFrame mode?) and resized to 1440x810 with adding top and bottom black bars - resulting in 1440x1080. This samples doesn't show the whole potential of the camcorder I think. The available samples for FX1 (e.g. at hd-channel.com) are deinterlaced using one of the best known algorithm and without changing resolution. But as you mentioned it won't be probably FX1 quality, but maybe a bit better than those sample - although it's allready good :) Regards |
<<<The available samples for FX1 (e.g. at hd-channel.com) are deinterlaced using one of the best known algorithm and without changing resolution.>>>>
What best known de-interlacer are you referring too? |
I can't find the info now at hd-channel.com, but when I was looking through sites with FX1 samples there was mentioned ReelSmart FieldsKit plugin or Magic Bullet. If you are interested in deinterlacing look also at free plugins for avisynth - the best is using motion interpolating algorithm.
Regards |
Thanks Michal Laskowski!
I am having trouble playing back the HD clip, it goes for a split second or so than pauses and all I get is the audio track. It could be the Duron 1300 (then I should get lots of chop) but have played back native HD10 clips, no problem. Any suggestions?
Wayne. |
DeInterlacers
The first one is the one embedded in the CineForm Aspect HD. From Premiere pro you can Export Movie in the wavelet based .avi format , and ask for the video to be deinterlaced with the help on some checkbox in the Video Rendering panel. The result is excellent, although you have absolutely no choice of any parameters. I also tried the FIeldsKit deinterlacer plugin from Vision Effects. http://www.revisionfx.com/rsfkdownloads.htm It can also be used from Premiere or from any AviSynth or similar program. You have a tremendous choice of parameters, providing effects and all. As far as simply deinterlacing is concerned, the result seem on par with the Cineform deinterlacing, or may be (very) slightly better if you take time to fine tune depending upon th enature of your footage. The counterpart is a higher rendering time... Worth trying to make your own mind... |
The clip - the full size one doesn't exist anymore. Maybe he got too much traffic and the server shut him down.
DBK |
