-   Sony Hard Drive and Memory Card Recorders (https://www.dvinfo.net/forum/sony-hard-drive-memory-card-recorders/)
-   -   Delay in recording on the MRC1 on an XHA1S? (https://www.dvinfo.net/forum/sony-hard-drive-memory-card-recorders/493458-delay-recording-mrc1-xha1s.html)
David Stembridge March 22nd, 2011 08:04 PM
Is there any way around this? I just got everything put together this evening, and doing some tests.... Was just wondering. Log and Transfer working great on FCP 7!!
Kevin McRoberts March 31st, 2011 07:39 AM
Re: Delay in recording on the MRC1 on an XHA1S?
Does the same thing with my Z1U... you can see if cache recording will work with your camera.
Adam Gold March 31st, 2011 01:45 PM
You shouldn't have this issue at all with a Z1. Make sure on the MRC you have set CAMLINK SEL to SYNCHRO, not FOLLOW. Also confirm you have EXT REC CTRL > REC CTRL MODE set to SYNCHRONOUS on the Z1
