CF Card Won't Mount Without Restart
Hi everyone,
I've been recording simultaneously to tape and the CF card, trying to get into a steady workflow with my z7. I've downloaded the Sony FCP plug-in and have been able to transfer the clips from my CF card to my Mac. The only problem is that I cannot get the CF card to mount on my computer unless I restart the computer itself. So, for instance, I can't just have my computer on and then plug the Memory Recording Unit via Firewire and have it show up when I open FCP>Log & Transfer. I have to restart the computer first, while the Recording Unit is attached--only then can I see the CF. This is a pain when I have to log and transfer from more than one card because I have to quit FCP, and restart the computer once I want to log and transfer from a new card in the same session. Is this normal? Anyone else had this problem? Any suggestions? I have tried using two different Firewire cables I have but they do the same...Wondering if it may have to do with having external hard-drives attached...? Any help is greatly appreciated! Raul New York, NY |
I don't use FCP but I shot some stuff on my MRC1 for another guy. We didn't use the MRC1 for playback. He had a little card reader that was plugged into a USB port, I think. He didn't have to shut down anything or restart anything. It worked just like you would expect. Perfectly.
Thank you guys!
It sounds like I should indeed invest in a CF reader rather than sticking with the MRC to log and transfer the clips. $15 seems reasonable enough to get around the problem of the MRC not mounting without restart. If I do figure out why it won't mount without the restart I'll let you know, though! So far no luck... Raul |
You could do one better and get a firewire 800 CF reader, this is the one that I use:
SanDisk | Products | Accessories | SanDisk ExtremeŽ Readers |
Thanks for the recommendation, Gary. The card readers that go for $15 or so at B&H don't have very good reviews and was looking at the Firewire ones. Firewire 800 would be the optimal in terms of time-saving speed.
I'm still wondering if others find that logging and transferring from the Memory Recording Unit is a very unstable process... I'm pretty appalled at how unstable it is in terms of its functionality when it comes to logging and transferring clips from the card to the computer. I was reading that somebody else was experiencing things such as opening the log and transfer window and not seeing anything for a minute or so, nor any indication that indeed FCP is seeing the card or trying to read from it... I definitely have the same experience... Anyway, in any case, seeking a card reader, like the one recommended by Gary should do the trick. I think perhaps I was expecting too much from the gear that came with the camera! Thanks again all for your help! Raul |
Ah, ok. Didn't think to try switching the mode in the menu... Will give that a shot.
Thanks for the tip, Boudewijn, Raul |
I find this very strange, because I haven been logging & transferring hunderds of clips via a firewire 800 reader to a Mac 8-core and it never failed. I even find this is the most reliable solution possible. Are you sure there's nothing with the firewire-socket on your Mac?
I must admit though that I had comparable problems with a PC. That's even the main reason I converted my entire equipment into Apple stuff. |
Received my Sandisk Firewire 800 reader yesterday - so far no problems unlike the MRC-1 which just plain won't be seen.
Hi Luc, it seems like the thing to do is get a card reader, as opposed to using the Memory Recording Unit that came with the camera.
You say you've been using a firewire 800 reader without a problem, but have you tried logging and trasnfering using the Memory Recording Unit that came with the z7? Do you have a link for the card reader you use, by the way? I'm sure my firewire connection is fine because I use it all the time for my external LaCie drives as well as for connecting my old Sony PD-170. I don't ever have a problem with the drives mounting through either firewire 800 or 400, nor do I ever have a problem seeing the PD-170 when I try to capture from there. But for some reason, when I connect the Memory Recording Unit from my z7, it just will not mount on my desktop, and, thus, I will not be able to see it, unless I restart the computer. That is the only way I can get it to show up--which is a pain to have to do every time I want to log clips from a different card... It seems others on here are having similar problems... I have yet to hear from someone who actually logs and transfers using the MRC-1 without a hitch. It seems like the best thing to do is skip using the MRC-1 and get a card reader. You would think, though, that the reader provided by Sony with the camera would do its job...Tsk Tsk... Raul |
Hi Raoul,
you're right, I only use the Lexar firewire 800 reader, like in this link:Lexar - Flash memory card readers - Pro CF Reader. The workflow with a reader that is always ready and mounted is much more straightforward. Anyway, I tried connecting the MRC1 in it's cradle, powered with a battery and I get the same problem: my Mac doesn't recognize it! Not a big problem, as I do have the Lexar reader, but you'd expect Sony to deliver something that works flawlessly, especially for the price they charge for it!.. |
