-   Sony Hard Drive and Memory Card Recorders (https://www.dvinfo.net/forum/sony-hard-drive-memory-card-recorders/)
-   -   Hvr-mrc1 audio files (https://www.dvinfo.net/forum/sony-hard-drive-memory-card-recorders/140595-hvr-mrc1-audio-files.html)
Marc Brewer December 31st, 2008 03:06 PM
When I import the files to my files in Dv or Raw format my final cut pro 5 suite sees the video and plays fine but I get the Beep Beep Beep in the audio track. I see the waveform and the file plays fine in QT AND the preview window....
any clue as to what's going on or do I just need to install FCS 2...?
Danny Aldaca January 19th, 2009 06:51 PM
You need to render your audio.
Bryan Daugherty January 20th, 2009 08:32 PM
Originally Posted by Kenny Pai (Post 997938)
Hi,
http://pro.sony.com/bbsccms/assets/f..._Workflows.pdf
You need to install a plug-in into your FCP(6.0.2+) in order to import HDV/DV files from your CF card.
FCP can not import M2T HDV files without this plug-in.
For DV files (AVI or Raw), "Beep Beep Beep" never occurs if you use this plug-in !!
This is the answer from another thread http://www.dvinfo.net/conf/tapeless-...ecorder-2.html I don't use FCP but this is the suggestion listed there. Best Wishes!
Marc Brewer February 3rd, 2009 09:27 AM
thanks a ton people, found the plugin on Sony website, upgrading FCP and soon will be off and running!
