-   Sony ENG / EFP Shoulder Mounts (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/)
-   -   HD component to HD-SDI adapter (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/98861-hd-component-hd-sdi-adapter.html)
Gerson Becker July 13th, 2007 09:08 AM
Anyone using a HD component to HD-SDI adapter?
Wich one?
Thanks.
Bob Armstrong August 8th, 2007 09:16 AM
Anyone ever try one of these? Any idea if it will allow you to take HD Component out of a HD direct TV box and allow it to be recorded on a deck bypassing the HDCP?
Terry Nixon August 13th, 2007 03:25 PM
We've used the AJA mini-convertors on several installed jobs with HD-SDI infrastructure.
The AJA HD10C2 converts HD-SDI to Component Analog HD.
The AJA HD10AVA goes the other direction, Analog component HD to HD-SDI.
http://www.aja.com/html/products_converters_mc.html
If you need SD to HD, or HD to SD converts, that's another even more expensive device.
Duncan Craig April 16th, 2010 02:15 AM
The AJA link has moved to http://www.aja.com/products/converters/
The AJA link has moved to MINI-CONVERTERS - AJA Video Systems
Anton Strauss April 16th, 2010 03:02 AM
this maybe worth a closer look
Blackmagic Design: UltraStudio Pro
Rick L. Allen April 16th, 2010 05:32 AM
I own the Blackmagic Analog to SDI converter and I am very happy with it. I use it to convert component out of my XDCAM HD to HD-SDI.
Blackmagic Design: Mini Converters
Uli Mors April 19th, 2010 02:20 AM
is there a one that can be powered from the camera (D-Tap out)?
Uli
Duncan Craig April 19th, 2010 06:54 AM
They mostly seem to be 5v DC. They're missing a trick there aren't they? 5-20v DC would be so much easier to deal with for professional onset.
Christopher Young April 19th, 2010 07:13 AM
The Blackmagic Mini Converters are all 12v
Peter Beeh April 19th, 2010 07:58 PM
I have a black magic hd-sdi to analogue mini converter. It's 12v and I have run it off d tap. Before I did this I spoke with Blackmagic's chief electronics man. From memory the essential conversation went along the lines that the converters will run between 11 and 13v dc. Above that and there is some sort of safety switch and the converter will not function - but theoretically won't be damaged... Keep this in mind because if you were to try running the device off dtap it will have to come from the a regulated 12v dtap. Many cameras offer this. You would not be able to run it directly from a well charged lithium battery with d tap as the voltage would be too high.
Uli Mors April 21st, 2010 02:36 AM
I never measured the dtap out on the sony cameras (at the handle front) if its regulated or simply put through...
Could this work?
As we speak I schedule a big project with HD live mixing - so I will have one or two component-to-HDSDI lines again...
ULI
Peter Beeh April 22nd, 2010 05:18 AM
I'm not sure if the in built dtap at the front of Sony cameras is always regulated. But certainly the digit betas I have used were and the PDW700 and F800 are. I have run my black magic mini converter off them.
Duncan Craig April 22nd, 2010 05:23 AM
I've just been informed of this little chap: Datavideo Technologies Co. DAC-8 - HD / SD-SDI to HDMI Converter
About the same price as a Blackmagic mini convertor, but accepts 9V to 15V DC.
Edit. But it might not work in 1080p, waiting for a response from my reseller.
Uli Mors April 23rd, 2010 12:55 AM
nice, but thats (HD)SDI to HDMI...
ULi
Duncan Craig April 23rd, 2010 05:56 AM
Oops my mistake. Try this:
SD-SDI Converters - DATAVIDEO DAC-7L (DAC7L DAC 7L) Stand Alone Y:U:V to SDI Converter
Uli Mors April 24th, 2010 02:03 AM
I see...
unfortunately it seems not to support HD conversion.
regards
ULi
Uli Mors April 24th, 2010 02:07 AM
12v Dtap out
reading is a good way to solve problems.
Here is what the pdw-f350 Manual states about the DTAP Connector on the side:
"is controlled to 12V even if the camcorder is powered with (...) more power".
So thats the way to run a converter box off a battery powered camera!
Regards
uli
