-   Sony ENG / EFP Shoulder Mounts (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/)
-   -   Quick Clip Delete (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/95259-quick-clip-delete.html)
Brian Jansen May 29th, 2007 07:38 AM
Quick Clip Delete
I thought I had seen a tip in the forum awhile back on how to delete a selected clip from the thumbnail menu using 2 key buttons < instead of entering the menu >
I can't seem to find the post.
Anyone remember the shortcut keys for this?
Kevin Spivey May 30th, 2007 03:55 PM
Select the clip you want to delete in the Thumbnail menu (the clip name turns yellow when selected)
Press CLIP MENU and SHIFT down at the same time.
Use the front Menu knob to select "Delete Clip" from the menu.
Confirm and delete.
Brian Jansen June 1st, 2007 07:03 AM
Thanks!! You can bypass the menu by using "shift - reset" buttons for deleting a clip. Thats the shortcut I was looking for.
Thanks for leading me to it.!
