-   Sony ENG / EFP Shoulder Mounts (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/)
-   -   PDW-F70 over a network? (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/93643-pdw-f70-over-network.html)
Mike Watson May 9th, 2007 03:16 PM
If I have three edit bays connected by GigE, can I mount the F-70 (FAM mode) on one of them, and access it from the other two? Logically, this should work, but I can't seem to make it.
Also, has anyone tried the GigE network card inside the F70? Can I then put the F70 in a machine room (or some such) and access it via network from there? Does the sony software to transfer to FCP still work?
-MW
William Osorio May 9th, 2007 11:26 PM
You need you get PDBK-101 Network Board from Sony and then you connect to your network.
This board provides network connectivity which enables the transfer of MXF files. These universal media files can be used to transfer both video/audio signals as well as important metadata. This metadata can hold pertinent information including camera settings and scene/take information.
You can also connect to a website and display unit info.
Proxy viewr software will work with this settings and your edting environment.
cost:::::::::::: 1,800 US
Andy Mees May 10th, 2007 12:43 AM
Mike,
Are you using a Mac?
I haven't tried it, but I would imagine you need to fully install the XDCAM Transfer software on all three Mac's as part of the bundle is the software needed to support the XDCAM disc's filesystem
If you go the network board route, AFAIK Sony's XDCAM Transfer on the Mac software does not currently support FAM via a network. In that case, you will need to buy Telestream/Flip4Mac's XDCAM Component http://www.flip4mac.com/pro_xdcam.htm
Cheers
Andy
Mike Watson May 10th, 2007 10:24 AM
Thanks Andy. I thought of you when I posted the question. :-)
I just found the Filp4Mac software this morning. I'm investigating it now.
-MW
Dan Brazda May 10th, 2007 12:29 PM
Be careful with the Flip4Mac for XDCam. I tried it a while ago and it doesn't seem to work with 24P material. If 24P isn't an issue for you then you should be OK. If anyone has had luck with XDCam HD shot at 24P and transferred via GIG-E with Flip4Mac XDCam 2.0 let me know how you made it work.
