Master Reset on The 350 & 330 XDCAM?
Where is the absolute most factory restore/rest
located in the 350 & 330 XDCAMs? |
Operations Menu then the Reset Page. You can then reset all settings to standard at the User level.
Also, You can return all settings in the User Menu to the standard settings by displaying the user file page of the File menu, selecting User Preset, and then select yes to set all settings in the User menu to standard settings. |
Bob, thank you for your reply.
My real problem is the I can't get my colors to match from my 350 to match my 330s. When the cameras are all reset the red levels are higher on the 350 at default I am guessing.... All menu settings appear the same from the reset 350 & 330s. All cameras have the same lenses side by side white ballanced and all reset, still have the problem...? Any suggestions? |
How do you look at the footage? Maybe a Component/SDI difference?
The footage is looked at on Final Cut Pro with this problem.
The 330s have component out monitoring and the 350 has HD-SDI monitor. All show the 350's native footage with more red in it than the 330's. |
maybe different firmware?
maybe needs a reset in service menu? |
-gb- |
| All times are GMT -6. The time now is 03:39 PM. |
