FCPro Edit Questions
Hi,
I am working at a client's facility which as FCPro edit bays. I have a couple of questions in regard to FCPro XDCAM transfer software: 1. We have a bin with clips ingested with PDZ-K transfer. Only sections of the original clips on the XDCAM discs were imported. The media as been erased from the drives, how do you re-ingest those clips from the FCPro bin? 2. The clips mentioned above are from a 2-camera shoot. I'd like to duplicate all the clips from camera A in the bin but import them from the camera B disc (both discs have match time code) to do a multicam cut. Is there any way to do this? Thanks for the help. Thierry. |
There's no real mechanism between FCP and the Transfer software, other than the import process. So both of the situations you are just going to have a human as the go between.
Unfortunately, the XDCAM flow on FCP right now doesn't jive too well with an offline/online traditional process. They just figure you'd want to bring almost everything in and edit full res. I have to say, having done that, it's not too troublesome. |
Hi Nate,
Thanks for your prompt reply, I'll pass it around. Thierry. |
And along with what Nate said, to make the re-ingest process a little easier.
With XDCAM Transfer app opened up, insert the same disc that has the clips you want to re-ingest. Goto View, Sort by, Subclips. This will put all clips that have in/out points marked at the top of the stack. Now you can rubber band select those clips and hit the import button. This is much easier than going through all the thumbnails and looking for which ones have the IN/OUT message displayed on them. -gb- |
| All times are GMT -6. The time now is 03:09 AM. |
