Half Inch Lens Adapters
If you buy a 2/3 to 1/2 inch lens adapter ensure that it has a glass element. Some of the cheaper adapters don't have any glass in them, they simply place the lens at the correct distance from the focal plane so that it will focus correctly.
The glass isn't a lens, it's just an optically flat piece of glass but it is needed to compensate for the different prisms. Without it there will be a small registration error between the R, G and B channels which will show up as slight fringing or image softening. |
Alister, I assume you have a glass one---what have you found the quality of images shooting 2/3 lens on the camera? |
May I assume the reverse is true as well... when going from a 1/2" mount on the F330 and F350 up to a 2/3" lens?
Have not tried any decent 2/3 inch lenses yet. As soon as I do I'll let you know.
1 Attachment(s)
For our Texas HD Shooutout we had to resort to a 2/3rd-inch adapter on an F350 that Scott Cantrell brought up from Houston (this was after Mike Devlin had to head home with his F350). Here's a pic. Thought I had a pic of the adapter by itself but I can't seem to locate it right now. Nor can I recall if this adapter had an optical element, but I can easily find that out.
The adaptor doesn't have an optical element. The focal length of the lens also multiplies by 1.37 with the adaptor attached.
Despite this magnification I would recommend using it with 2/3" lenses over getting 1/2" ones simply because 2/3" lenses will last you longer and allow you to 'upgrade' to a 2/3" HD camera later. |
Which 2/3 inch lens do you like? Chris, which 2/3 lens did you use during the shootout? |
-gb- |
So guys, how did the XDCAM HD do in the shootout? |
I'm leaving that one for Adam Wilt to answer in his article for DV Magazine. Plenty of other folks who were present for this might have their own input though.
- to much loss in angle of view - to much loss in light sensitivity (at least 1/2 step) - makes the camera forward heavy because it pushes the lens further forward. Thierry. |
