-   Sony ENG / EFP Shoulder Mounts (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/)
-   -   PMW-400 RGB or YCBCR out via SDI? (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/524670-pmw-400-rgb-ycbcr-out-via-sdi.html)
Rob Hargreaves August 26th, 2014 03:13 AM
I have a problem with my Neway reference monitor on the SDI input and the Manufacturers in China are asking whether the output from the PMW-400 is RGB or YCBCR from the HD-SDI?
Would anyone know what colorspace the Sony PMW-400 (or similar models) output via HD-SDI?
Jack Zhang August 26th, 2014 09:59 AM
Re: PMW-400 RGB or YCBCR out via SDI?
All HD-SDI up to 1080i should be Component 10bit 4:2:2, which is YCBCR. Remember, RGB is equivalent to 4:4:4.
Rob Hargreaves August 27th, 2014 05:33 AM
Great, thanks!
Alister Chapman August 28th, 2014 05:17 AM
RGB is not always 4:4:4 RGB can be 4:2:2 and YCbCr can be 4:4:4. RGB is most commonly 4:4:4, but just because something claims to be RGB it is most definitely not a a guarantee that it is 4:4:4.
But as Jack said the HDSDI out is indeed YCbCr.
