Choppy result - for some time - on Bluray
I experienced something very awkward when burning edited movies from my XDCAM-HD (PDW-F350) to Bluray disk: whenever there's a panning or other motion, the first few seconds the image stutters, but after that everything moves smoothly. So there a a few seconds of choppy video, followed by perfect footage.
How is this possible? Is it a Bluray encoding artefact? (Shot in HD, 25p, edited in FCP, exported to QT in ProRes 422 and encoded that QT-movie to Bluray). |
what output setting do you have in the Blu-ray player setup menu?
mine can be set to 1080p or 1080i or 720p |
Bitrate may be too high?
Just a thought but if your encoding for the bluray was using too high a bitrate that might have this effect - you didn't say what SW you are using to do the encoding?
FCP7? Something else? Dave |
Bluray was burnt with 1080, movie was inported in Toast bluray burner in Quicktime (ProRes422). Editing was done in FCP 6 - starting from original clips in XDCAM-HD, 25 p. The Quicktime movie does not suffer from this effect, only the Bluray result.
did you output mpeg or H264 for the blu-ray
what max bitrate did you use for video and audio when I use mpeg, I usually set fixed bitrate to 24000 (max at 35000 if using variable) for video and 384 for ac3 audio |
Anton, in Toast 10, there's very little I can choose as far as bitrate and burning speed are concerned. The 'burning speed' box is not even lighted up, so I cannot choose any of this. I'm using XDCAM 25 p variable bitrate to make the Quicktime movie, is that any help?
but what are you putting on the blu-ray, it can only be mpeg or h264 or some other vc1 format that nobody uses
MPEG, I suppose, there's no choice as far as I can see. Even in the 'recorder settings' there's no menu that offers format alternatives.
sorry, but after doing lots of Blu-ray, I can assure you that there is no room for "I suppose"
a cheap encoding and authoring tool can be found at TMPGEnc - We Make Digital Video Easy! |
I just bought Roxio's Toast 10 + HD-Plug in for 250,- euros. Will the software you mention give me better quality and more control of the burning process on a Mac? Authoring is not so important for me, top quality image is.
ouch, don't think there is a Mac version
Dont know if its relevant but in all my IPTV tests I have had a lot of problems using long gop material for transcoding to web and DVD, dont know about blu ray but for a lot of my tests I had to transcode to flash to stabilise the stream.
Now I am on panasonic P2 with intra frame codecs it never happens anymore. |
Anton, I talked to somenone yesterday who has some experience with Bluray, and he told me that this is a typical bluray problem. The very first frames of any new movement (pan, tilt, zoom) are choppy, then the movement smoothens. That's exactly what I'm experiencing. Have you experienced this too? I cannot imagine all bluray-users accepting this as 'normal'.
Any other suggestions? Gary, Thanks for the info. The strange thing is that 90% of the movement is OK and smooth. It only stutters just in the very beginning. I know the problem you describe, but that represents itself al along the movie when there's a pan or a tilt, not just for a few seconds at the start of every fresh movement. Most of the footage looks fantastic, only when panning, zooming or tilting there is this strange 'stutter' that stabilizes immediately afterwards. |
I saw that stutter several times when I was on long gop and as you say its at the start, it was almost like some form of encoding buffer was trying to catch up and re-sync the frames.
Making material progressive seemed to improve it but I had lots of hours spent with problems uploading material that had been re-compressed for delivery. As said I dont have those problems now so whether the 35mbs long gop codecs dont like re-compressing or not I dont know. |
That indeed sounds like the same problem, Gary. I'm always using progressive mode, so it's not awful, just a little disturbing (and distracting). Did you eventually find a solution to get rid of it?
I also posted this on the Bluray authoring forum a week ago, but all I got was only 48 readers, no repliers... |
| All times are GMT -6. The time now is 03:09 AM. |
