SRW-9000 HDCAM SR Camcorder at DVinfo.net
Old April 19th, 2009, 06:53 AM   #1
Sponsor: Abel CineTech
Sony is releasing a new HDCAM SR based camera. It'll be shoulder mount like the XDCAM series but recording to HDCAM SR Tape. It'll output 1-60 fps in 1080 with some option boards installed. Check out the link below for more information.
[×îÐÂ×ÊѶ]SONYз¢ SRW-9000 Éã¼HDCAM SRÒ»Ìå»ú - Ó°ÊÓÆ÷²Äר¼Ò--Æ÷²Ä²âÆÀ/Ñ¡¹º×Éѯ - Öйú×î´óµÄDV´ÓÒµÕßÉçÇø-1394ÂÛ̳ DVÂÛ̳|¶þÊÖDV|¶þÊÖÉãÏñ»ú|ÉãÏñ»úÂÛ̳|ÉãÏñʦÂÛ̳|ÉãÏñÒ¡±Û|Ó°ÊÓÖÆ×÷|Ó°ÊÓÆ÷²Ä×âÁÞ|·Ç±àÂÛ̳|AEÂÛ̳|¸ßÇåÉã Ïñ»ú|¹ã²¥¼¶ÉãÏñ»ú×âÁÞ - Powered by
Watch this site for more info when they post it - Welcome to the NAB 2009 Virtual Press Kit
SONY UNVEILS FIRST CAMCORDER BASED ON HDCAM SR FORMAT
LAS VEGAS (NAB Booth #C11001) April 19, 2009 – Sony is unveiling the next generation of digital 24P technology, the SRW-9000 HDCAM SR™ camcorder. Designed for television, commercial and motion picture production, the new model combines the format’s image quality with the versatility of a one-piece camcorder.
The full HD (1920 x 1080) resolution camcorder uses 2/3-inch CCDs with a 14-bit A/D converter and digital signal processing to capture up to 1080/60P images with a high level of detail. In standard configuration, the camcorder is capable of 4:2:2 10-bit recording at 1080/23.98P, 24P, 25P, 29.97P, and 1080/50i/59.94i. It can also record 4:2:2 1080/50P/59.94P.
“The HDCAM SR format is proven in the most demanding digital cinematography applications,” said Rob Willox, director of marketing, Sony Electronics’ content creation group. “Applying that legacy into a compact one-piece body design adds more flexibility to location work and is more ‘Steadicam®-friendly’ as a B-camera complement to the F23. This mobile and cost-effective acquisition tool can further expand the use of HDCAM SR technology to a much broader audience.”
A range of option cards are available for additional performance and features. The HKSR-9001 option board adds dual-link HD-SDI outputs and an extra AUX input port for connectivity to an external audio multiplexing device.
A picture cache board (HKSR-9002) will allow the camcorder to capture and record images with variable speed (SR Motion™ capability) from 1 to 60 fps. It also allows the camcorder to continuously record up to three seconds of video while the camcorder is in stand-by mode. When the record button is pushed, the stored images are recorded to HDCAM SR tape and the camcorder can continue recording in real time.
With the optional HKSR-9003 RGB 4:4:4 processing board, the camcorder offers full-bandwidth digital 4:4:4 high-definition RGB recording and output capability. The option also offers S-LOG Gamma, which is essentially a “digital negative,” allowing users to flexibly tailor their images during post-production in the same way they would in a film-based workflow.
Complementing all HDCAM SR technologies is Sony’s line of BCT-SR Series HDCAM SR digital videocassettes. These cassettes are designed and co-engineered to fully maximize the benefits of 4:4:4 RGB recording technology.
HDCAM SR recording media uses ultrafine high performance metal particles 50 percent smaller than those in Sony’s HDCAM tape applied in the thinnest magnetic coating, to enable wavelength recording to 0.29mm. The result is up to +7dB higher output than HDCAM tape.
The SRW-9000 is compatible with a wide range of accessories for Sony’s HDW-F900 and F23 cameras, SRW-1 deck, and ARRI camera systems. Its physical size is equivalent to Sony’s original HDW-F900 camcorder.
In addition, the SRW-9000 accepts the new HDVF-C30WR viewfinder, which is specially suited for Sony’s F series cameras, and offers the new Focus Assist Function. The new viewfinder also provides pre-installed viewing look-up tables (LUTs) for S-Log Gamma, enabling easy focus adjustment and intuitive photo-shooting operation.
The SRW-9000 HDCAM SR camcorder is planned to be available in December, with suggested list pricing to be announced.
Andy Shipsides -Camera Technology Specialist
AbelCineTech, New York - Visit our Blog - http://blog.abelcine.com
Andy Shipsides is offline   Reply With Quote
Old April 21st, 2009, 02:37 AM   #2
It doesn't get any awards for beauty! Has to be the ugliest camera I've seen in ages.
Old April 21st, 2009, 04:28 AM   #3
Ah haaah! The lightbulb has gone on. I reckon this syncs with my idea that they have now started the gradual phase out of normal HDCAM and explains the PDW-800 nicely.
Simon Wyndham is offline   Reply With Quote
Old April 29th, 2009, 11:47 AM   #4
Starway Pictures
I overheard someone from BandPro saying that people will be shocked how low the price will be. Really. Does that mean instead of $150K it'll be $125K? *Roll Eyes*
The PDW-800 is $42,000. I'm sure the SRW-9000 will be stratospheric in price.
Robert Sanders is offline   Reply With Quote
Old April 30th, 2009, 01:15 AM   #5
I'm sure you're right, partly because it's the tape part that tends to be expensive, one of the reasons why solid state cameras can be made relatively cheaply.
Also, I get the feeling the price will be released as a base camera and then there will be all the add ons at an extra charge - so for example 1-60fps overcranking and 4:4:4 recording boards may well be £10,000 each!
Steve
Old April 30th, 2009, 02:46 PM   #6
Steve is correct. The base camera is 4:2:2 and missing a few other options. I overheard the figure of $125k for the basic camera being mentioned at NAB, but that might not be correct.
Old May 1st, 2009, 03:27 AM   #7
Sony seem to be pushing it as a B camera to the F23, but for most productions SRW 9000 would make more sense as the A camera.
Old May 1st, 2009, 01:20 PM   #8
Not sure why they are pushing it as a B camera to the F23 too. It shares the same front end so there should be no difference in picture quality. The SRW 9000 will certainly be a good camera for stedicam use and perhaps in that situation they would regard it as a B camera. Where it would be a good B camera is with an F35.
Makes me chuckle as when I think of B cameras I normally think of EX1's and lower priced cameras, while the 9000 is a camera many would aspire to have as their A camera!
Old May 2nd, 2009, 03:22 AM   #9
I suspect it's for those productions that need a second camera of the same quality shooting multi camera or as the backup camera on a feature film.
I'd imagine a similar version of the F35 is not far behind, apparently there's no difference behind the sensor stage between the F23 and the F35.
For most work I can't see the F23 staying around in the longer term. The old dockable camera/VTR Betacam SP kits slipped away from the scene when the BVW200-400 camcorder series came out.
Old May 5th, 2009, 08:08 AM   #10
I've updated Andy's post with the full text of the Sony press release and an image (unfortunately very low-res, but the only one available at the moment).
Old May 5th, 2009, 02:47 PM   #11
There is a short video blog about the SRW-9000 on the sonybiz.net site:
Sony : NAB : United Kingdom
Scroll through the blogs and you'll find it.
There is also some text about it:
Sony : Introducing SRW-9000 HDCAM SR Camcorder : United Kingdom
Old May 12th, 2009, 07:55 AM   #12
I've heard that base price may be around $80k but that is just a rumor. I think the F23 is a very pretty camera, and with all the options installed the 9000 is basically the same thing. And the 9000 should fit in many more productions than the F23, with a much more portable form factor. Finally a F900 killer has arrived.
Old June 11th, 2009, 12:13 PM   #13
Seemingly it has a F900 optical block, so perhaps it's more a F900 recording onto HDCAM SR and perhaps that would expect why Sony regard it as a B camera to the F23.
Old June 11th, 2009, 02:22 PM   #14
That excellent HDC-1500 block is finding it's way into many cameras including this one and the PDW-700
Old June 11th, 2009, 02:31 PM   #15
Also the same block as the F23 and the PDW-F800
Bill Long is offline   Reply
