Slow-Motion with the PDW700
Hey guys,
A couple people have asked me how to convert 720 60p footage into slow motion. I wrote up this post on our new blog to explain my process: Slow-Mo PDW700 Footage | CineTechnica By the way, we just launch a new blog - CineTechnica Check it out and see what we've been up to. Andy |
Added the blog to my favourites right away! Keep up the good work guys.
Using Media Manager to recompress?
Andy,
We are back to the 25p/23.98p issue on the PDW700 and we are having to conform 25p to 24p and needing to recompress footage to PRHQ-25p to do this. ] First, does it make sense to use the 25p to 24p option on the tools menu vs. Cinematools as posted in your blog? (the footage is b-roll without the need for sync audio, but this could change). Second, I found with h.264 compression that Compressor was much faster than FCP at exporting media (using 8 core Intel 3.0Ghz system). Is there a benefit to using Media Manager to do this? Thanks, Jim |
Jim
The CinemaTools method and the Conform 25p to 24p method work in very much the same way. CinemaTools has a host of other features that you don't need so I would just stick with Conform 25 to 24. You may find audio problems with either method, but I would need to do some testing. In terms of using Compressor versus Media Manager I would just go with whichever is faster. Media Manager is just very easy use when working with multiple clips. Andy |
-gb- |
| All times are GMT -6. The time now is 12:27 AM. |
