-   Sony ENG / EFP Shoulder Mounts (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/)
-   -   PDW700 5pin Male to 2 x 3pin Female cable (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/143937-pdw700-5pin-male-2-x-3pin-female-cable.html)
James Venturi February 16th, 2009 07:49 PM
In the manual this cable is listed as part of the included accessories, but we didn't receive one with our camera--is this normal?
Jim
Stewart Menelaws February 17th, 2009 03:20 AM
We received one with our PDW-700…
Regards: Stu
www.studioscotland.com
Rick L. Allen February 17th, 2009 05:49 AM
You can always make your own.
Sony 5 pin XLR wiring
Pin
1 Gnd
2 Left + hot
3 Left - cold
4 Right + hot
5 Right - cold
Thierry Humeau February 17th, 2009 09:37 AM
$30 at BH
Sony | 5-Pin XLR Female to 2 3-Pin XLR Male XLR | CCXA53//A
James Venturi February 17th, 2009 12:42 PM
Opposite
5 pin male to 2 x 3 pin female is what is required.
Thierry Humeau February 17th, 2009 09:37 PM
Nope, it is the other way around. If you want to send the audio out of the camera to two separate XLR cables, the Y-adaptor listed above is the correct one to get. Also, note the audio is line level OUT.
Thierry
James Venturi February 17th, 2009 09:58 PM
But I want to get audio into the camera--CH3/4 which is a 5 pin female xlr and needs to be 3 pin female to accept mic/line inputs.
Thierry Humeau February 18th, 2009 11:01 PM
There is no 5-pin female audio input on the camera. The only 5-pin (male) on the camera is for line anallog audio-out 2-channel only. You can feed audio to CH 3 or 4 by using the 2 XLR audio inputs on the back of the camera as long as your audio channels assignment switches on the side of the camera properly select CH3/4. These two audio inputs can operate in either analog mode (2 channels only, 1 audio channel per XLR) or AES/EBU (total of 4 channels, 2 on each XLR input).
Thierry.
Ivan Snoeckx February 19th, 2009 11:33 AM
On the front you'll have a 5-pin female connector that normally is used for the camera microphone.
Thierry Humeau February 19th, 2009 01:28 PM
You are right but this is a mic level only 2-CH input. I just kept looking at the camera's usual I/Os. Would make sense to use this input for 4CH production if you can cope whith the mic level.
Thanks for your contribution.
Thierry.
Bryan Harvey February 23rd, 2009 07:27 AM
I received one with my camera.
