-   Sony ENG / EFP Shoulder Mounts (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/)
-   -   Non-stop time-code (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/117928-non-stop-time-code.html)
Eric Emerick March 27th, 2008 01:25 PM
Non-stop time-code
My TCG is running continuously. I have tried to re-set it with no success. Whether in R-Run, Regen or F-Run, it's all the same. I would appreciate any pointers on this, thanks.
Greg Boston March 27th, 2008 02:11 PM
Sounds like you have cache recording turned on. So in essence, the camera is always recording, but stops flushing the buffer when you actually hit record.
-gb-
Eric Emerick March 27th, 2008 03:04 PM
Bingo, you are good, much thanks. One more thing while I'm thinking about it. I thought I lost the cover for the lens connection on the camera. I called Sony, where they told me they had no such part in their system. I find it hard to believe that the cam shipped without such a part, I just don't remember. Who is right, me or Sony?
Ivan Snoeckx March 27th, 2008 04:22 PM
Sony is right. There is no cover like that.
Greg Boston March 27th, 2008 05:03 PM
Beg to differ Ivan, I have a plastic cover on my lens connector since I'm using the 1/2 lens with hot contacts in the lens mount. The camera certainly ships with one. Maybe they don't offer it as a spare part.
Maybe the SD cameras don't include a cover since it's certain that the lens connector will be used with 2/3 lenses.
-gb-
Ivan Snoeckx March 28th, 2008 08:17 AM
Ooops! I never knew that. The F-330 that I have owned until two weeks ago was a second hand and it did not include such a cover. So I thought there was not such a thing. My fault
Then Greg is right and Ivan is wrong!
Eric Emerick March 28th, 2008 08:51 AM
And Eric is out of luck. I'll have to double my effort to find it here in this jungle I call an office, thanks again.
Greg Boston March 28th, 2008 12:11 PM
Originally Posted by Ivan Snoeckx (Post 849940)
The F-330 that I have owned until two weeks ago...
So Ivan, what did you replace it with?
-gb-
Greg Boston March 28th, 2008 12:14 PM
You might be able to improvise with one of those plastic end caps for metal chair feet, etc. at your local home improvement store. I just looked at mine and it isn't all that different.
-gb-
Ivan Snoeckx March 28th, 2008 01:56 PM
At the moment I have no camera anymore! If I need one, I have to rent, or use my cousins DVCAM. The buyer of my 330 with lens gave me a very good price, but wanted it to have immediately.
Normally I'm going to get a new F-355. But I'll wait to order after NAB to see what Canon is going to come up with. Hope they come with a 2x extender version of the KH13x4.5 KRS. Early may I'm also going to the presentation of the new PDW-700. But I doubt that for the work I'm doing it is justified to get a pricy killer machine like that.
Eric Emerick March 28th, 2008 03:58 PM
found it
I found a Sony parts company in Miami that can order it for me. I'll know in 2-3 weeks if it's indeed the part I'm looking for. It's listed as lens mount cap, sounds right to me.
Greg Boston March 28th, 2008 05:47 PM
That sounds like the cap you put in the bayonet mount when you remove your lens. Is that what you were originally looking for? I was of the impression that you were looking for the small cap that covers the 2/3 lens cable connector on the right-front of the body.
-gb-
Eric Emerick March 28th, 2008 09:19 PM
Ah, no, the bayonet mount cap is what I was looking for, not the 2/3 lens cable connector. Sorry I wasn't clear on that.
