New Firmware and Memory Stick
Is the memory stick still limited to 128mb even after the 1.93 update?
Yes. The special jig that was required in the earlier update also required installing a slightly different firmware revision as well, for updating to Memory Stick Duo support. I didn't feel the need for that so I used the non Memory Stick Duo version which required no special jig.
-gb- |
So B&H has Sony 128mb memory stick duos in stock (with adapter) but you're saying that won't work without the "jig"? If the answer is no, you know what I'll ask next....
Where do you get the old 128mb memory sticks now? |
-gb- |
Thanks Greg. I'll grab a couple of 128mb duos and I'll be fine.
What uses the most amount of memory on the MS? I'm still running with a 32Mb stick and it seems fine so far - not saved a huge amount of user setting etc though...
I leave the firmware on my MS all the time and really haven't come close to using it up. The main reason for getting beyond the 128mb stick has more to do with availability of the smaller capacity cards than necessity for data storage. -gb- |
Jig question
I found 8MB memory sticks to work very well. The camera reads them really fast and you can find them on eBay for really, really cheap. A while ago, I won a bundle of 20 for $2.25....
Thierry. |
This is what I did. Updated to PKG 1.62 with AT 1.53 and all was well. Now, I've just updated to the latest and everything is still okay. -gb- |
I just downloaded the 1.62 package from this website https://servicesplus.us.sony.biz. I can't find any mention in the notes and I don't see anywhere that I can choose an AT pkg other than 1.54. Is there a different download site you are using? The 1.53 version would be fine because we have a bunch of the non PRO 128mb memory sticks.
Found the correct site after my second call to support. ftp://storage@ftp.sony.com. Going to try an upgrade now. Thanks Greg.
There is no updated Fresh file for the current firmware release, just PKG and AT. -gb- |
Greg I need your help here please:::::
Hi Greg I have
AT:1.53 Package: 1.62 installed on my 350, I remember that for users who don't want to go with extra capacity on MS were able to update to this version without buying the MS-69A board ( A-1356-823-A ) right?? My question is:: Can I do an upgrade to PKG 1.93/AT 1.60 from my courrent version without going first to PKG 1.62/AT 1.54 Please advice, Thanks in advance William Osorio |
-gb- |
I never did the update with the MS-69A board (A-1356-823-A) I went from prior version to AT:1.53 Package: 1.62 without the board. So I’m okay to go the latest version PKG 1.93/AT 1.60 from AT:1.53 Package: 1.62?? Don’t need to buy MS-69A board (A-1356-823-A)?? If so tell me where to buy MS-69A board (A-1356-823-A). please Thanks William |
-gb- |
Is it possible to check what FRESH version is installed?
Yes, turn on full user menu, go to Maintenance and find the page that lists ROM versions. That's where you'll find all the firmware versions.
-gb- |
Greg:
Actually no... I found out that you have to go to the SERVICE MENU to see this. (And I suppose you ment DIAGNOSTICS - but there you can only see versions of AT and PACKAGE, not FRESH). Strangely enough - I have to use the DIP-switch inside the camera to get to the SERVICE MENU. I cant use the "ZEBRA"-way. That's a bit strange - I have succeded all the updates (now having FRESH 1.06, AT1.70 and PACKAGE 1.98). |
That's correct. I was going by memory. It's the service menu ROM page that shows all the different firmware versions. My bad.
-gb- |
| All times are GMT -6. The time now is 08:14 AM. |
