a7s iii and S-Cinetone Test Video
Re: a7s iii and S-Cinetone Test Video
Thanks for the sample footage, but I have to say that I don't care for the look. It seems very contrasty to me me with blacks that are too deep and mid-tones that seem too dark. S-Cinetone is supposed to be a WYSIWYG look, but I think this absolutely would need to be graded to at least bring up the mid-tones. And the shutter speeds seems way too fast. Just my opinion.
1 Attachment(s)
I have attached info on the metadata on one of the original clips - they are all identical. |
Mark, you are welcome to shoot any way you want to, but 1/128th is not the recognized correct shutter speed for 60 fps unless you are shooting for slow-motion. the correct shutter speed for 60 fps is 1/60th. You chose the perfect clip to show the metadata because that just happened to be one of the ones that looked the worst to me. There is no motion blur when he is waving his hands around. We can agree to disagree if you want to, but I am not wrong. It is your creative choice and I happen to disagree with it and do not like the look.
You are wrong about what is considered the appropriate fps that merits violating the 180-degree rule, which I followed (the camera shutter speed was set to 125th of a second). What you believe is hardly the consensus for 60 fps video played at and viewed at 60 fps. If viewed at 30p, yes, the shutter speed is too high. It would be great if others weighed in on the issue of frame rate/shutter speed. I do not have anything to protect. |
Most people will view at 30 fps or 60i, therefore the speed is too high. 60 fps playback is non-standard. You obviously feel quite passionate about it, so I hereby grant you official permission to choose whatever shutter speed you want. Would you like a notorized letter?
I think I qualify to be considered part of the "older generation", however, contrary to your hypothesis, I definitely prefer brighter colors and deeper contrast. I think you are probably 180 degrees incorrect about what generation prefers what look. But regardless of who likes what, blown out highlights and crushed blacks are never acceptable. People can disagree on shutter speed, but some things are not open to debate. My 2 cents.
I think I qualify to be considered part of the "older generarion", however, contrary to your hypothesis, I definitely prefer brighter colors and deeper contrast. I think you are probably 180 degrees incorrect about which generation prefers which look. But regardless of which generation prefers which look, blown out highlights and crushed blacks are never acceptable. People can disagree on shutter speed, but some things are not open to debate.
To me it looks mostly under exposed and with a grey-ish cast over it. I can see the colour in it, but for all the work that goes into the workflow it simply isn't worth it if that is all you are getting out of it.
BTW, get the notarised letter from Doug. It's a great offer and will only become more valuable with time. Andrew |
Shutter Speed Too High Hogwash
What I feel passionate about is criticism that is both curt and incorrect. Some do feel passionate about 60 fps being the only frame rate that provides proper motion and that at that frame rate shutter speeds of at least double are appropriate. I actually do not care that much about that issue. I do care about anyone implying that I do not know what I am doing, unless I actually do not! Then, pour it on. Btw, I agree with you on S-Cinetone - I prefer more color than S-Cinetone provides and I like the flexibility of the DR of the latest sensors, which S-Cinetone does not exploit fully. |
But, I am confused about your workflow comment - Sony's point about S-Cinetone is that you have minimal workflow - you get a "cinematic" look with no work. You have the sign wrong, or I am confused by what you said. The point is if you don't like the look of S-Cinetone, then you have to get to work and exploit those log profiles. |
I'm thinking within reasonable limits, the great majority of viewers won't care at all about blown highlights, black greys, shutter speed effects. This, I think goes beyond. The grey overall and especially the grey skin is dominant, the effect contrasted by some over saturated mids, But look, this is subjective, only an opinion, you're the creator and the creative choices are yours, trust your own judgement..
