Kitchen
I've recently had a new kitchen fitted so I picked up my A7s and filmed a bit to send to the designer so she could see how her plan worked out
Re: Kitchen
Why is there so much aliasing artefacts? Did you use fulframe mode with 50P?
Re: Kitchen
Yes full frame @ 50p - downsized to 1080X720 6Mbps target I'm not seeing many artifacts?
Re: Kitchen
1 Attachment(s)
Take a look at the door handles. They are living in most shots.
Avoid to use FF at 50P. Its a mode, that can`t (like 120P) make use of full sensor reading. Its terrible compared to FF in 25P (or APS-C in both 25P and 50P). 25P has a clean - perfectly detailed sharp picture absolutelly free of moire and aliasing. |
Re: Kitchen
Ivan the reason I used 50p is I wanted really slow tracking movements, my slider is a glidetrack which is an igus slider and sticks a little when sliding slowly - for a slow consistant speed I push it fairly quickly and slow it down 50% on the timeline - 25p would not allow me this
Re: Kitchen
Yes - i know. I would love 50P in my A7S in full frame too. But nothing is perfect.
One of biggest advantages of this camera is full readout of the sensor - not possible in this mode. I love smooth slow slider movements too. For this i decided to buy the fantastic edelkrone slider with action and target module. It let me realize beuatifull movements, that are impossible manually. |
Re: Kitchen
Ivan I'm a little confused - are you saying the A7s does not use the full sensor in 50p mode? does using 50p mode engage crop sensor as in APS mode?
I can't find any reference to this in the manual. Pete |
Re: Kitchen
You have to use crop mode if you are using 50/60P or you will get that horrendous aliasing. Or.....just shoot organic soft BG subjects that don't have a lot of fine detail. Then it works.
Re: Kitchen
50P have to be twice as faster... and this is probably not possible at this technology level. There is 50P - but only at the "old school" technology level. The some for 120P. APS-C is smaler and can be read faster - so its at the best quality in 50P too. |
Re: Kitchen
Of course the downside to that is my lenses are all EF and crop when the camera is set to APS-C mode - I could use my speedbooster but that's usually attached to my EA50 and certainly during a wedding shoot don't have time to do all the juggling around.
Re: Kitchen
What lens did you use? james
Re: Kitchen
James I used a Tamron 24-70mm f2.8 - I also use Canon 24-105mm f4.0, Canon 70-20mm f2.8 and a Samyang 14mm
All for full frame cameras (EF mount) Pete |
