-   Sony 4K Ultra HD Handhelds (https://www.dvinfo.net/forum/sony-4k-ultra-hd-handhelds/)
-   -   PXW-Z90 best setting in low light? (https://www.dvinfo.net/forum/sony-4k-ultra-hd-handhelds/535478-pxw-z90-best-setting-low-light.html)
Pierre Vidailhet February 27th, 2018 02:13 AM
I have to film a Gospel concert and there is not much light what is the best setting in low light ?
Thank you for your help
Cliff Totten February 27th, 2018 01:06 PM
Re: PXW-Z90 best setting in low light?
Probably the biggest thing you could do is bite the bullet, break the 180 degree rule and drop down to a 1/30 shutter. None of the picture profiles will actually bring in more "light" but slowing your shutter down to 1/30 actually does accomplish this.
Try to shoot as wide as you can because zooming in will close your aperture. So,...the closer you can position yourself to the action, the less you will need to zoom and the faster your lens will be.
Not too much more you can do than that. The rest is just "gain" in different forms.
CT
Roland Achini February 27th, 2018 02:17 PM
Use LOW LUX mode. This is only available if the camera is in Auto Mode and Gain Limit is set to off.
You also may set BLACK GAMMA (black stretch) for low light (range: low). The recommended setting is LOW +7, which brings up the black stretch in the darker areas. With the 10 bit 4:2:2 codec, you can then push the blacks down in post without problems.
Pierre Vidailhet February 28th, 2018 09:37 AM
CT
thanks for your help
Pierre Vidailhet February 28th, 2018 09:39 AM
Paul Anderegg February 28th, 2018 08:29 PM
I do a lot of low light high gain shooting...I find that adding any black gamma just ads a lot of noise as gain increases. I adjusted my DETAIL settings to Type 1 and crispening to +1 to knock down some of the noise "enhancement" you get as the gain increases. In NLE, I sometimes will pull my midtones (gamma) downward until the contrast looks pleasing, and as you pull down midtones you also reduce noise a bit and get back some contrast you lose as gain increases.
Paul
