PXW-Z90 MPEG-TS 720p 3Mbps live streaming
The 5Ghz WiFi band, and allowance of 1280x720 30p when in 60p record codecs, make the new Z90 a very capable one man band live to air broadcast camera. My X70 was always hobbled by 360p/1.5Mbps 2.4Ghz freezing stuttering connections. Below is a demonstration of the cameras built in live streaming function, through a 5Ghz HotSpot from an LTE-Advanced Galaxy S7 phone.
Re: PXW-Z90 MPEG-TS 720p 3Mbps live streaming
Paul, how do you cope with the (on my system) 9 second lag that I have when streaming to Youtube. The only way I can think of is to use another cell phone for voiceover and anticipate the visual.
I think MPEG-TS has a native 2 or so second delay. We have a Teradek Cube receiver, hooked to the interweb through a dedicated line, so it doesn't need to bounce around an intranet or anything else other than the 4G network, our ISP, then spits out to our on air play system.
YouTube TRANSCODES your stream, and routes it through their system and network, so there is a built in delay there. Paul |
I am sure others like me wanted to know (or maybe did not) this. That's the difference between pro and hobby.
Paul -
I always been curious why there was that delay because you'd think that someone in the station would have the reporter on hold or standby and ready to go at the push of the "On Air" button (or what ever). |
Sat feeds have a delay, also, bonded cellular solutions have a selectable delay...my station has TVU's set to 2 second latency. The longer the latency, the more error correction that is available. Fun TV news fact, that nodding yes you see them do to take up time...it's called "bobble", as in bobble heads :)
Paul |
For what it's worth, here is the same camera when set to Sony proprietary QoS Network Connection Mode...about 600Kbps less video rate compared to MPEG-TS, but that 600Kbps goes to the QoS packet loss recovery error correction system.
Here is a slightly higher bitrate test, 3.4Mbps.
| All times are GMT -6. The time now is 12:38 PM. |
