-   Sony 4K Ultra HD Handhelds (https://www.dvinfo.net/forum/sony-4k-ultra-hd-handhelds/)
-   -   Is XAVC Long-G 35 and 25 also 10 bit 4:2:2? (https://www.dvinfo.net/forum/sony-4k-ultra-hd-handhelds/530650-xavc-long-g-35-25-also-10-bit-4-2-2-a.html)
Brian Tori December 15th, 2015 10:05 AM
Hard to find answer to this even on Sony sites. Just wondering if both of these are 10 bit and 4:2:2 or is it only the 50Mb version?
Cliff Totten December 15th, 2015 01:33 PM
Re: Is XAVC Long-G 35 and 25 also 10 bit 4:2:2?
10bit 4:2:2 is only on the 50mbp/s setting.
35mbp/s and lower are 8bit 4:2:0.
50mbp/s 10bit 4:2:2 is already a very low 1080 bit rate as it is in h.264. So Sony would probably never try to push 10bit in anything lower than 50mbp/s.
Monday Isa December 15th, 2015 08:22 PM
XAVC-L HD on my FS7 is 10-bit for all the bitrates. I would imagine it would be the same on the X70 since it's using XAVC-L.
Alister stated it's 10-bit in all modes in his review:
Sony PXW-X70 Review | XDCAM-USER.COM
Also in the press release it states 10-bit for all 3 bitrates:
Sony Announces PXW-X70 XDCAM Professional Compact Camcorder
"When recording in XAVC, the PXW-X70 uses the MXF file format, efficiently compressing full HD (1920 x 1080) resolution using the MPEG-4 AVC/H.264 CODEC.
Image sampling is 4:2:2 10-bit with high-efficiency Long-GOP compression at 50 Mbps, 35 Mbps or 25 Mbps."
Paul Anderegg December 16th, 2015 12:39 AM
I don't remember there being a 25Mbps option on my record format option?????
Paul
Monday Isa December 16th, 2015 04:45 AM
60i and 50i can go down to 25mbp/s.
Paul Anderegg December 16th, 2015 04:55 AM
Oh.......my eyeballs do not see INTERLACED related objects, they get "tuned out"! :-D
Paul
Brian Tori January 11th, 2016 01:17 PM
Thanks guys.
So in conclusion the 35Mb mode is 10 bit, while the 25 Mb mode is 10 bit but only 50i or 60i correct?
Monday Isa January 11th, 2016 01:19 PM
That is correct.
