Re: 60Mbp/s vs. 100Mbps - Supprising Video Samples
Now panning 2160 in 30p shutter 1/50
https://ssl.unlp.sk/x70/Clip0100.MXF https://ssl.unlp.sk/x70/Clip0098.MXF btw. new vegas out Notable fixes/changes version 13.0 (Build 453) -Fixed a bug that could cause the application to crash when using the Median or Min and Max video effects with an NVIDIA GPU. -Fixed an issue that prevented Vegas Pro 13 from importing XAVC-L files recorded by the PXW-X70 camera. -Fixed a bug that prevented XAVC long-GOP files rendered by Vegas Pro from playing on the PXW-X180 camera. -Fixed an issue that caused the Wave Hammer Surround plug-in to run in Demo mode. The plug-in is now enabled in Vegas Pro. -Improved playback performance for some MP4 video clips recorded by GoPro Hero cameras. |
Much better panning in 30p, but only with VLC. Vegas still slow and jerky.
I think in Vegas again is problem with accelerating this 4k xavc. Try Sony Catalyst Browse if problem too.
@ Zenes: Could you upload the complete folder from the SDXC-card to test the function with Final Cut Pro X, but only the mxf isn`t recognized by FCP X, who needs the complete card-folder, so the testfiles only readable by Catalyst Browse. Thank you.
Four more 4k clips from X70 in directory structure
https://ssl.unlp.sk/x70/PRIVATE.ZIP (640MB) https://ssl.unlp.sk/x70/Clip0153T01.JPG https://ssl.unlp.sk/x70/Clip0120T01.JPG https://ssl.unlp.sk/x70/Clip0114T01.JPG https://ssl.unlp.sk/x70/Clip0115T01.JPG |
Beautiful - were is the lake in Czech?
this is in Slovakia, High Tatras, Strbske pleso
I thought at first time tatra, because I read you are in Czech. It is a nice place there!
3 Attachment(s)
60Mbps vs 100Mbps on the AX100.
It's subtle, and it surprised me, but it's there. The 100mbps shows less aftifacting, macroblocking and smearing, in the darks especially. I pushed these images pretty far with by brightening up the mids considerably and adding a pretty intense LUT. Please note that I didn't try to make the images look good, but instead tried to show the differences in the bitrate by grading it intensely. See what I mean by looking at the brown box in shadow underneath the case on the shelf. FWIW screen grabs attached. (can't attach the 100mbps wide for some reason, but you can see the differences in the CU) |
So, I'm still not sure that the teeny weeny difference in quality is worth the doubling in file size going to 100mbps?
Less artifacting when panning........I see it in the 100 Mps
Anyone have access to these files? I need to download them
*Edit* no longer needed |
| All times are GMT -6. The time now is 01:21 PM. |
