-   Silicon Imaging SI-2K (https://www.dvinfo.net/forum/silicon-imaging-si-2k/)
-   -   SiliconDVR's Software Options (https://www.dvinfo.net/forum/silicon-imaging-si-2k/80369-silicondvrs-software-options.html)
Karina Nemuhina November 25th, 2006 06:35 PM
For those of us planning on buying the full SI2K (the Mini), I request we recieve Software Copies of SiliconDVR that can run on external notebooks (just like the Mini SI2K).
This is to remove the restrictions of working with the Embedded WINXP enviroment in situations where we need additional software functionallity.
For instance we might need to run Color Calibration software like Cinespace in the background e.t.c.
Thanks.
Ari Presler November 26th, 2006 07:16 PM
This could be possible....but not free. Each copy of SiliconDVR incude 3rd-party software licences and are keyed to specific machines.
Karina Nemuhina November 29th, 2006 07:49 PM
Will we be able to install critical software like color callibration software under the Embeded WinXP enviroment.
Carlos Osterling November 29th, 2006 09:21 PM
A bit confused
Sorry if this is a dumb question, but... is the SI2K the same camera as the Mini? I am interested in getting the bigger (boxy) camera, if that is the case, what is the name of this version. Thank you.
Ari Presler November 30th, 2006 12:52 AM
SI-2K is the full camera with embedded Core 2 recording systems (aka DVR). The 2K-MINI, or MINI for short, is the removable front end of the SI-2K.
Ari Presler November 30th, 2006 12:54 AM
The intent is not to enable install of additional 3rd party applications which may effect the perfromance or reliablity of the system. Use a separate notebook to create your looks and bring them to the camera using USB Thumb or HDD.
Karina Nemuhina November 30th, 2006 05:15 PM
Licence Transfer for SiliconDVR
Will the licences be transferable for the SiliconDVR software , in the case of SI2K -Mini.This is in case of Laptop failure etc.
Ari Presler November 30th, 2006 06:31 PM
Yes. There is a mechanism for transfering a licenses from one machine to another.
