-   Silicon Imaging SI-2K (https://www.dvinfo.net/forum/silicon-imaging-si-2k/)
-   -   SI-2K Iridas Color Management. (https://www.dvinfo.net/forum/silicon-imaging-si-2k/80367-si-2k-iridas-color-management.html)
Karina Nemuhina November 25th, 2006 06:17 PM
Hi,
With respect to the article: http://www.siliconimaging.com/Digita...2K_Iridas.html on your website, as well as previous posts on this forum, i'd love to ask the following questions:
1. Earlier posts (http://www.dvinfo.net/conf/showthread.php?t=78212) pointed to Speedgrade OnSet being bundled with SI2K, please verify.
2. Will the Iridas Color Management Workflow be applicable as well to 12 -bit uncompressed Raw images in addition to CineformRaw?
3. In the diagram- Iridas Color Management Pipeline, there was an "Optional - Seperate View LUT to Mimic Final Print with On-Set Monitoring".Please elaborate on that in terms of equipment/software & added costs (if any?)?
4. Could you be more descriptive on how the final non-destructive color correction of RAW data will be accomplished in Premiere Pro.
Ari Presler November 26th, 2006 08:51 PM
> We will be offering Speedgrade OnSet 2006 to be used with the camera and CineformRAW Metadata for $399. We may offer special software bundles for some cost savings.
> Silicon Imaging and Iridas are working together in several areas. We do already support real-time in-camera .look visualization while recording 12-bit uncompressed files and metadata.
> You can load up to 4 .looks at any one time and select them each individualy for either record look or view look (or LUT) independantly.
> The .look metadata will be applied just like it is previewed in camera. However, you will still have the option to select a different look to apply in Premier with prospect-2K.
