-   Silicon Imaging SI-2K (https://www.dvinfo.net/forum/silicon-imaging-si-2k/)
-   -   F Mount (https://www.dvinfo.net/forum/silicon-imaging-si-2k/79968-f-mount.html)
Ian Savage November 19th, 2006 05:22 AM
F Mount
Is this still an option or will an adaptor be available ?
And if so should you buy the C or PL mount version and are they themselves able to be swapped ie: if you buy the C mount can you simply buy the PL adaptor to use etc
Ari Presler November 19th, 2006 01:31 PM
The standard camera has C-mount. You can order the PL-Mount which is added to the front of the camera. There are various inexpensive C-to-F mount adapaters on the market. However, we do plan on offering a hefty F-mount option in a similar configuration as the PL-Mount.
