Motion Control
It's probably too late to get this in, but this camera could lend itself to motion control work (Star Wars..VFX stuff), using the camera head, ethernet and no body...not even needing sound...
What would be nice, is a simple option to play back just captured clips in reverse. Don't know how hard that would be to put into the software interface, so not expecting it first round. |
Unfortunately that won't make it to the first software release . . . while the feature may seem very "simple" on the surface, there's actually some deep codec-level adjustments that would have to be made first in order for this to even be possible.
Thanks, I didn't think it was simple, just don't know how hard it is.
Yeh, it's a low-level issue . . . it's not so much getting and displaying frames in reverse (like uncompressed), but actually decoding the stream in reverse, and furthermore decoding it in real-time (given enough time, you can do anything, but the need to maintain normal playback rates puts limitations on what one can do on modern hardware), which is quite a different story, and will take some re-working at the codec-level.
I imagine the typical backwards effects shot, shouldn't last over 3 or 4 seconds.
I think even an SD rez rough might work. Or possible, an option that records sequential files instead of Cineform, just for effects shots. Then send the good ones off to post. |
Reverse Playback
Joe,
1.) Do you need the reverse playback to occur as you take each shot or can this be done in another application sitting on the recorders network? 2.) What is max time duration for such a shot? |
2. Most effects and animation shots never go over 7 seconds but occasionally might go to 10 ,like a long closeup simulated dolly shot of a space ship. This should't be confused with a 'scene' which may contain several effects shots. I'm hoping you can add output to Cineon, Dpx or OpenExr... so they could immediately be placed into the pipeline once approved. Create or provide a simple app to play the files forward or backward instead of trying to modify your capture app or codec. For modifying the image, the end users can provide their own software. They may even provide their own playback software, but it would be good customer service to offer one, even a good free one. The same capture PC would probably have software to control the motion arm holding the camera and remote control software/hardware (maybe wireless) to adjust focus. If that could be integrated into the capture app at some later date, that would be awesome. Check out the new open source media player from jahshaka.org for an example, they are claiming the ability to play back up to 4K. I'm asking about this, because I don't think production companies want to be forced to have ProspectHD licenses all over the place, especially in widely dispersed locations around the world. Thanks for responding to my ideas. |
Player Ap
Joe,
Excellent input. We have discussed it internally. We will plan on offering a dedicated player with reverse capability. We will also have an ap with a full render engine for conversion to a variety of formats. Today, you can already grab your short clip and export it as a sequnce of DNG's within the application. Develop them, colorize them and convert them today as you please and put into any player. We will just offer another product which will be more seamless. We have a new strategic partnership in the works, which will enable these capabilities in a very short time. Look for some major announcements in the next two weeks :-) ! |
