Minimum PC requirements
I've been reading that's possible to capture to a simple PC from your camera head...
...to a core duo laptop above 2.0Ghz or even tablet PC? (because I'm far away from the IT side, I'm not sure if there is Core Duo processors there) ...what are the minimum PC requirements? ...what is the weight of the camera nose? In this configuration, is there how to capture the audio together with the 10-bits Cineform signal to the PC? And if not (or even besides), timecode option to audio synchro capturing? (Following my ignorance dealing with computers, I'm sorry but I don't know what I might about this workflow... Merci! *EDIT* $12,500? Including Cineform software, right? Is it immediately available from now? |
Here's what it says about this on the Cineform web site. Apparently you need a mega-beefy computer for full ProspectHD perfromance:
http://www.cineform.com/products/ProspectHDConfig.htm |
I doubt those prospect HD specs have a lot to do with the cineform RAW capture. Those have to do with HD-SDI ingest which is 10bit 4:2:2, 2x the data that the siliconimaging camera captures (bayer is like 2:2:0, kinda... or maybe 0:2:2...). also from what i understand the codec is different, since cineform raw was made to be captured portably. I still have no doubt the requirements will be high, probably requiring a higher end core duo or any athlon x2 (so no matter what you are spending at least 35W of power on the CPU). just a guess though. I saw the system they are selling runs with a core duo and probably isnt completely small or light or quiet.
The min config system for SI/CineformRAW recording is a 2.1GHz core duo, dual DDR2 667 and Intel GigE. For Prospect-HD (multi-sream editing)you will likely want a beefier desktop/workstation (assuming not for battery power operation). You can always record on the same system as you do editing. Yes...$12.5K
I will have to check the weight (is there a target while we redesign the mechanicals). What lens(es) do you plan on using? We do record PC-Audio 48/16 into the .AVI file and Time of Day Time Code. USB TC sync will be added. |
Any more details about system requirements? Is dual core required due to multiple threads for preview and compression etc? its specifically multithreading optimized then? Is intel hardware a necessity? why? From what i've seen AMD's dual core desktop cpus likely beat out core duo and are available in equivalent thermal configurations, they also have more existing platforms and lower prices as they have been around longer.
Regarding audio, the timecode then comes from the computer system? Is that accurate enough? I thought the bios clock only had about 30ms accuracy? or is the timing directly from the cpu cock? |
Yes, the program along with the encoder is very multi-threaded, and loves multiple processors.
Also another thing it likes is a decent graphics card (DirectX 9) and good memory bandwidth (dual channel memory is recommended) Right now we've found that the 2.0Ghz Core Duo's run really nice. They both encode and decode the Cineform RAW footage at 1080/24/25P very well. At 1080/30P, you'll want to jump up to the 2.1Ghz Core Duo and dual-channel memory. Also make sure that you have 2GB of memory. While you can get by with 1GB, we RAM buffer very heavily, so while we save anything that is shot if you have a RAM buffer over-run, it can be a little bit of a pain to have to start up again after one. So basically any of the new Core Duo laptops with discreet graphics chipsets (the GMA950 will be supported in the final release, but right now we're supporting Nvidia chipsets) will work great as long as they have Intel gig-e (specifically the Intel gigabit ethernet chipset, not Broadcom, not Marvell, etc.), Nvidia graphics, dual channel memory, and a 2.0Ghz Core Duo. The above mentioned system should run you around $2-2.5K, but the nice thing is that it can double as an editing system when you're not shooting. In regards to the timecode . . . the timecode syncs to the system clock, but the actual frame-rate comes from the camera head's clock, which runs at 3ppm, not 30ppm like the computer clock. Timecode syncs when you first start the program, and then runs off the camera head clock (in free-run Time-of-day), not the computer time. We are working on other timecode modes like record-run, preset, and LTC timecode sycning with external devices. Hope this helps, Jason |
AMD vs Intel
AMD dual-core systems and multi-processor systems can be used as well. For low power applications we have found the Intel's are doing slightly better with our application.
Mes amis,
1) processors & PCs Quote:
2) audio, timecode & availability Quote:
And the $12,500 offer will be available when? Now? Is it possible to buy it now? And to wait for the final version upgraded next September? *EDIT* lenses Quote:
Hi Mathieu,
>> Just a curiosity: and about an AMD Turion 64 bits? I don't think we've had feedback on 64-bit systems. But should work fine, and maybe burst I/O is faster (with 64-bit Windows) >> Uncompressed audio already done? Already done: 48K, 16-bit, 2-channel. Later, depending on exactly what our customers want, 24-bit recording via Firewire/USB/ASIO. This has been tested, although there may be tweaks to the synchronization. With the SI-1920, I only use C-mount lenses, all spherical. cheers, Kyle |
Salut Kyle,
Silicon Imaging Team? Or just a customer? Quote:
Bonjour Mathieu,
>> Silicon Imaging Team? Or just a customer? I started working with Ari as a customer/developer about two years ago, although it was clear that the project I wanted to do (build 3D camera system with industrial, "machine vision" cameras, 12-bit uncompressed), had some overlap with where he and Steve wanted to take SI. I met Steve at a trade show in Stuttgart, in October 2004. Soon after the first versions of our digital cinema application blossomed, and I got to work with the SI-1920, color and mono. I now work full time with Ari and Jason, as software engineer. Basically, they design it, I program it. > And with an AMD Turion 64 bits but working with the 32-bits operating system available by now? Should work absolutely fine, no problem. > Upgrade available then? Absolutely. Software upgrades will actually happen fairly regularly. But if 24-bit (and/or 96 KHZ) audio is an ABSOLUTE requirement, mention that to Ari and Jason. Audio requirments tend to vary quite a bit, from scratch audio only, to 4-channel 24/96, etc.) >> From the camera head? Embedded audio together with the 10-bits Cineform signal? Or you're referring the timecode in order to the audio recording separately to an external device? I meant the embedded audio with Cineform. > timecode in order to the audio recording separately to an external device? Jason has plans for this, LTC etc., and I should let him answer. Sorry. cheers, Kyle PS: Ari is scouting for a new name for the camera. I suggested "VIGO". Not only in honor of the creator of "L'Atalante", but also for Boris Kaufman, cameraman for Jean Vigo, and also cinematographer for "On the Waterfront". Vous pourriez m'aider... ;-) We can figure out what VIGO stands for later. |
BTW, FYI
24/96, if you require it, can't be embedded in the AVI stream, or we break VFW compatibility. So don't look for 24/96 until we have QT working around 3Q'06. BTW, I've mentioned this before, but without good pre-amps, 24/96 is overkill . . . you're just digitizing noise and useless bits. The current audio implementations work great and run in-sync. The only issues are that we don't have all the timecode options available right now . . . we just have time-of-day free run. This works great though for syncing to external devices with a timecode slate or camera reports. Thanks, Jason |
But now isn't it yet possible in any way other than as 48K, 16-bit, 2-channel and if so, I'm asking if also as embedded audio with Cineform already from the camera head ($12,500 configuration) though 16/48 ? Quote:
When you're referring QT it means at PC users as well, right? And after that, for your customers who bought now the $12,500 bundle will it be possible an upgrade option to 24/48? As firmware upgrade or even hardware upgrade? Quote:
*EDIT* Quote:
Audio Support
The Audio recording is done in the PC not the remote camera head. The current recording application can record Audio from the PC inputs (WAV device) at 48K/16b into the AVI (Audio Video Interleaved) file.
Future releases of the software will have QT support. At that time we can incorporate higher bit depth and rate support. This will require suitable external audio devices. We would like to chose one or two devices to recommend (likely USB). Any recommendations? |
