-   Silicon Imaging SI-2K (https://www.dvinfo.net/forum/silicon-imaging-si-2k/)
-   -   Did someone already tested a telescope as "super-tele-lens"? (https://www.dvinfo.net/forum/silicon-imaging-si-2k/127826-did-someone-already-tested-telescope-super-tele-lens.html)
Stefan von Halenbach August 11th, 2008 08:58 AM
As i have read, it is possible to put a c-mount lens connector on the head of the SI-camera, it should be possible with a T-2 to c-mount adaptor to use your newtonian scope as cheap lens. The image has to be swapped horizontally,though.
Did someone already tried this? Is the picture bright enough on daylight? Could you post an example picture?
Bob Hart August 11th, 2008 05:16 PM
Consumer scopes might not be sharp enough.
That level of magnification also brings with it problems of haze diffusion and softness.
I've tried the MTO 1084mm f11 mirror telephoto which was available with a C-Mount on a CP16 and Bolex cinecamera, also 2/3" consumer video cam circa 1983.
The image was distinctly soft in those formats, sharper with 35mm.
The optical path of the MTO is described as "Maksutov-Cassegrain", not "Newtonian", which might perform better.
This frame grab is from a 35mm adaptor with this lens.
http://www.dvinfo.net/media/hart/agusmto3.JPG
The adaptor was capable of resolving to about 700 TV lines at that point of development and is not representative of what the SI2K offers.
Stefan von Halenbach August 12th, 2008 04:28 AM
Not too bad for a hazy day
Thank you for replying!
I thought to use the scope for the near field (3-12 meters) to have the DOF of a 35mm camera. Anyway, thank you for your example photo. It clearly shows the dust in the air. For such a far shoot, you usually have to wait just after the rain.
Stefan
