While Steve is away, this old wizened grayheaded mouse finally got to play with the SI2K.
There was one more final installment to the "Sonic Sessions" series at Fremantle Arts Centre tonight. The usual disparate camera line-up was there :- Two REDs One SI2K Two JVC GY-HD100s with Paolo Ciccone's Truecolor V3 selected. One Sony PMW-EX1 One Sony HVR-Z1P I tried "adaptive mode" tonight and that seems to have fixed the buffer over run issue we had one or two mishaps with. Interestingly, the buffer usage seems to be aggravated by conservative practice I use with Long GOP HDV cameras when lots of movement is happening. That is, I go wider to reduce the movement and the workload on the codec. Detail, even static detail in combination with movements within the shot, seems to push the buffer usage more than large movements in a much closer shot with a plain background behind. So when buffer usage was creeping up a bit high, I would go in and lock off the tripod on a medium close-up for a while until the indicator subsided. Steve Rice's own camera comes back very soon with the latest firmware installed so it will be interesting to see what difference there is. We have the P+S demo cam at the moment. It has the look of a well worked camera but is still kicking without laying down on us. |
Fox featherweight twentyeight trailer project
4 Attachment(s)
The SI2K is getting some exercise again over here, this time in a much more modest project, a pre-production promotional trailer which may or may not amount to anything.
Here's some grabs anyway from our first day shoot. There has been no colour grade, only some gamma and brightness-contrast adjustment. It was shot a little hot. The Tungsten look file has been applied to the raw image. Yes there are shadows. We had some redheads but no scrims and very short time to shoot in so went with what we had. Lenslist :- Zeiss-ARRI 25mm. Zeiss-ARRI 16mm. Cinema Products Ultra T 12.5mm. The context in which the frame fit is as follows :- Spoiler time. Dusan is a clandestine agent. He has just been identified as Marko, one of his previous personas by the man at the cafe table. Thanks to the Elizabethan Village Shakespeare's Tavern for venue access and to some of the bandmembers of "Village Green" for being the musoes having a jam at the Tavern. INT. VILLAGE SHOP - DAY Outside a gloomy interior, Dusan and Lucas pass the window view of two men seated inside. Dusan and Lucas enter. Dusan selects a few items, drops them into a cardboard box and then heads for a bar counter. Lucas runs ahead. Two young to middle-aged men sit at a wallside table with a rough meal. They glance across. CUSTOMER 1 When did you get the new wife Marko. Didn't know you still had it in you to breed a son at your age. Lucas does not like the look of the men or their familiarity with Dusan whom they address as Marko and gives them a hard look. DUSAN/FOULSHAM I should be so lucky. (to Lucas) Shht. You not talk with this man. Be kid lost his voice. Ask not why just do, --- I mean not do, okay? Customer 1 raises his hand and points a finger as if aiming a pistol in Lucas' direction. Lucas becomes apprehensive. His imagination makes the extra step and there is a revolver momentarily visible from his POV in the man's hand. CUSTOMER 1 Be see'in you Marko. |
Went back to the Elizabethan to pickup one shot we did not have time for the previous shoot day. This time we had an experienced DP to help us along in spite of limited lighting and crew resources
The filebased system showed its worth for us to be able to recall the previous shoot and match up the camera view exactly as the live and playback views come via the same screen. After the Elizabethan wrapped, we went to an outdoors location on a nearby orchard and shot among rows of stone-fruit trees just cropping. Our lens list was T1.3 CP Ultra and a Sigmatel for Nikon f1.8 135mm prime. We put a Skater dolly on MDF panels dogged down to aluminium trestles with clamps at the joints to reduce jump as the wheels rolled across and did a combined 12ft lateral track and pan follow through close peach foliage. The images look fine. There is now a large battery box to supply the camera. The significant thing to me is that the system just operates in the background now, is not distracting people into a shock and awe reaction but just does what it does without drama or glitch, a true production tool. Outdoors in the heat there were no problems. The quick file recall is very handy for slack inexperienced directors (me) whose ambitions have got ahead of diligent note taking and the inevitable question rises - did we cover that - find it - play it back - yes we did. No excuses for the slackitude. Nice feature to have on hand without the worry of rolling back tape and running the risk of damaging a tape or even worse miscuing and recording over earlier footage if the end-search hits a timecode gap. |
4 Attachment(s)
Here are a few grabs from a scene we shot on the weekend. Not in the league of Slumdog of course but our little modest no-budget effort.
Grabs are straight off an ungraded take with Kodak 250 daylight look applied. Image display order is :- 1.2. 3.4. Settings were :- Format - 2048 x 1152 in Adaptive mode Frame Rate - 25P Shutter - 1/50th sec Lenslist :- Cinema Products UltraT* 16mm. (flary on highlights due to damage). Frame 1. Cinema Products UltraT* 25mm. Frame 4. Sigmatel for Nikon 135mm f1.8. Frames 2 and 3. For those with a curiosity for things vintage mechanical, the tractor is a 1956 vintage Ransomes MG6, repowered with a Kubota 11hp diesel from a Japanese rice harvester. |
Here are a couple of web addresses to more finessed assemblies of Scene 8 and 9 of the Fox Featherweight Trailer trailer shot on the SI2K system.
For reason of the limitation of the editing computer when dealing with 2K origination, the camera files were given a grade in Prospect4K then exported as Blackmagic files for the actual assembly/edit. FOX FEATHERWEIGHT TWENTYEIGHT PRE-PRODUCTION PROMOTIONAL TRAILER - SCN 8 ASSEMBLY. By Bob Hart On ExposureRoom FOX FEATHERWEIGHT TWENTYEIGHT PRE-PRODUCTION PROMOTIONAL TRAILER - SCENE 9 ASSEMBLY. By Bob Hart On ExposureRoom A password may be applied to these in the next day or so. We would have liked to have had a shallower depth of field on the long shot of the tractor approaching however had no NDs or IR correction filters at the time. |
BTW, Bob, if you ever need a little more contrast control in a high-contrast out-door setting like what I'm seeing in your footage, you can try the "Medium Contrast" version of the Kodak 250D, or the "Neutral Medium Contrast", or even the "Neutral Low Contrast" looks.
The medium and low-contrast looks open up the shadows a bit more, and lower the point along the curve where middle-grey exposure is, so you get more headroom. For instance, in a daylight setting, the low-contrast look can give you a good +5 f-stop headroom over-exposure range, so that only the most extreme highlights will clip. The only downside to the lower-contrast looks that push down the middle-grey point is that they do induce a bit more noise into the scene, but typically with a high-contrast daylight shot, noise is not an issue (noise in the shadows would typically only be an issue during a night or low-key scene). Thanks, Jason |
Jason.
Thanks again for your advice. Ideally we would have used ND to bring in a little more selective focus but had none. Gavan put a polariser on which helped. Our light out here can be a bit savage and climate change is not helping. I have been around enough years to observe the difference. The skies are what I call hard nowadays. Clouds about 30 degrees up from the southern horizon used to be lighter than the sky about midday, now they are a slight shade darker most times. Maybe my eyes are going off but I don't think so. |
In airs with the "split" SI2K"
Next weekend, we will be doing some stuff within a light aircraft, some of which will be dialogue delivery in flight to lend some authenticity to the other shots we will do in more controllable conditions with the aircraft mute and silent on the ground.
For a sync track for looping, we will take a feed from the aircraft comms system. For safety reasons we may not ND the side windows to bring the background light down to a more manageable level so may have to make do with flight toward the sun to light the interior through the front screen which is less than ideal. The camera recorder unit and Mini head will be startrekked (split). The Mini head will be positioned handheld on a short pole into the ideal shooting position that safety will permit. The pole will support the camera in an underslung position and will be safely restrained by lanyards with enough free length to permit handheld support free of vibrating airframe. The recorder unit and touchscreen monitor will be secured down in the cargo area and the operator will pole the camera forward from the rear seat. We will be using a Kinoptik 5.7mm, which is not the sharpest kid on the block but about the only lens that does not require critical focus once the backfocus oir collimation to the mount has been achieved. Its sweetest spot is f4 which may give us a problem if the day is bright. We are in f11 - f16 weather right now. It is also the model before the in-built filter slot was added so there are no ND filter options except maybe some gel across the front or in back of the exit pupil. Does anyone have any furthur advice to give us? |
For the lens use Kowa 5mm, very sharp and nice, no distortion and will not break your budget.
http://www.digitalsputnik.com/skll/T...etry_plane.mov Shot about a year ago, well outside window is easier but I had the lens 2xND.8 screw in filter and wired remote FF on aperture wheel to compensate. Lens was 8mm Navitar The sky is not your worst enemy but the clouds. So try to keep the frame slightly upwards and you should not have many problems. Also you could make a look that pulls the neutral grey 1.5 stops up, so you have much more headroom. As for mounting the mini head, use magic arm and super-clamp, no need to do handheld! For DOP monitor you could use VGA extender, but dont forget you need to power it. few ideas.... -Kaspar |
Kaspar.
Thanks for linking your clip. Interesting mid-way through the flight there is an apparent disturbance trail through the cloud layer suggesting the passage of an earlier flight on the same heading. Kowa apparently made the Ultra T* series lenses for Cinema Products Corp. We have a Manfrotto geared head but it is a bit too heavy to be attaching to the diagonal struts across the windscreen on our light aircraft, a Maule which are critical parts of the airframe. We also cannot clamp onto tubular structural elements due to risk of crush damage. We could but the risks are just not worth it. We would also be on the wrong end of some law and order, so it has to be hand-held for us. |
In Airs with "split" SI2K
4 Attachment(s)
Here's a few grabs from today's adventures. A rough grade only.
Lenslist. Actual Airbournes - Kinoptik 5.7mm at f4-f5.6 On ground emulation - Noct-Nikkor 58mm at varying from f4 to f1.2 as light was lost due to time over-run. The framing/composition of the ultra-wides is a bit off. This was forced on me by the confined workspace and the wide view of the Kinoptik which would otherwise pick up the camera/lighting pole I was using. The shots were effectively locked off with only limited range of movement available. When pilot and passenger were looking ahead, the composition was fairly okay. Due to my mismanagement the wides were .mov files and the close-ups were .avi files. The .mov files were given a hasty colour/gamma adjustment, the .avi files got the quick Kodak 250 print look applied. Now I need to rest my weary bones and sleep. FOOTNOTE: Here is the bit of vision grab 3 was extracted from :- http://exposureroom.com/members/DARA...714d445c8a62f/ |
2 Attachment(s)
Here are a few pieces from last weekend. The SI2K again was operated in a "split" configuration. You may observe a bit of fixed pattern noise. One needs to remember to redo the "set black" after the camera has been on for a while. - I forgot.
FOX FEATHERWEIGHT TWENTYEIGHT SCN6 SHORTFIELD LANDING By Bob Hart On ExposureRoom FOX FEATHERWEIGHT TWENTYEIGHT SCN6 EXTRACT By Bob Hart On ExposureRoom Yes. - I know there is no trigger on the prop gun and I have been told it is smaller than the real thing. It was made in haste out of bed iron, chair tube, tractor pins, poprivets and other scraps and apparently the cocking lever is on top not the side. Well I can't always get it right and we don't have the real things running around in Australia to borrow or copy from. We are probably all the better off for that fact. |
Correct POst Method with SI2K footage
My DP and I have had a discussion on grading and post with SI2K footage.
Our question is, what is the correct or best way to grade the footage. Not knowing better, our sense is that one applies the grade to the cineform raw file then render this out to the exhibition format. Should the looks be used to final grade from or are they intended only to be a quick previewing tool? Our situation is that because we are lacking computer horsepower, the SI2K footage is being given a fairly good preliminary grade over the raw image with cineform 32bit levels and colour correction tools with no look file applied. Then it is being exported to blackmagic codec for assembly/edit and final finesse of the grade. Any advice will be greatly appreciated. |
Hi Bob,
The post house that I've a bit of work with here doesn't use the .look files but does use the white balance information. They cut on FCP, once the edit is locked down they export the cut to Pro Res and do their grading in Apple Color. These jobs have mostly been TV commercials & a couple of music clips. With Cineform releasing FirstLight I'm hoping to convince them to keep the .looks and just do their final little grading tweaks in Color instead of trying to recreate the whole look of the shot. Ofcourse the best option would be to have a grading suit with Iridas Speed Grade that can work with the RAW and .look without having to bake in the white bal or colour. |
Using the SI2K in split mode for in-airs
For those who have an interest, here is a preliminary assembly of SCN5.
FOX FEATHERWEIGHT TWENTYEIGHT PRE-PRODUCTION TRAILER SCENE 5 ASSEMBLY By Bob Hart On ExposureRoom (Aircraft enthusiasts and sound purists will pick the background FX sound of a Lycoming powered Cessna 172 instead of the Lycoming powered Maule M5 it should be. Still, this is no less legitimate than mainstream sound designers sexing up the sound of a Bell Jet Ranger with the signature heavier rotor beat of the Bell UH1.) You may observe a fixed pattern artifact in the ground-to-airs - my mismanagement of the system. Firstly, make sure you set your black levels. Secondly, make sure you set your black levels. Thirdly, make sure you set your black levels and when setting black levels, don't be a nidiot and forget to cap the lens. Am hoping to do a short Australian scene for the international shoot of the US based feature "Seeking Closure" on one day of the weekend May 30th-31st in Malaga. |
Si2k in the rain
Went on a recent shoot with SI2K owner in wet and rainy conditions. Obvious precautions apply as with any camera system. After an overnight shoot we found an artifact in low light conditions (early am twilight), switched heads and on later test of the original head after it had been relaxing for a while in a drier environment, found the problem was gone.
We suspect it may have been condensation built up on or near the sensor as there was a bit of a patchy dark blue sheen visible on the sensor from outside which later was gone. The system seems intended to be weather resistant to the odd drops and splashes from rain covers being removed. I found myself becoming more concerned with protecting the lenses. This leads me to wonder how the proposed new RED system, which appears to be stackable modules on rods, will cope with the wet with all those thin gaps in between modules for stray water drops to wick into. Unless they introduce overlapping faces with grommets or grommet the piggyback electrical conductors between the stackable modules, there will be a serious problem in the conditions we faced this past two days. Also got to play with some real bells and whistles, big jib arm on Elemack on rails for an indoors location. The project and location have to be kept discreet for now but hopefully I can advise of a website in the not too distant future. |
Thanks for keeping us informed on your progress. Don't feel bad about the black balance problem. I soon discovered that doing a black balance without lens cap and with iris open can give some 'interesting' results. Thankfully in my case the result was so bad it was obvious in the viewfinder.
Slightly alter-topic.
Gavan O"Sullivan, who has generously DPed for me on the Fox Featherweight trailer scenes shot so far, had in his shed some left-overs from his days of owning and operating a 35mm ARRI BL film camera which he sold a few years ago. The lenses had originally come with this camera but he had updated to Zeiss Ultras which departed with the camera. The lenses in the shed had been stored long term as backups but never needed. He passed them to me to try on the SI2K. These are Cooke "Speed Panchro Series II" 50mm T2.3 and 75mm T2.3. Both were inhabited by fungus from living in Indonesia and Singapore for some years. As old cine lenses they exhibit the wear and tear of being workhorses with cleaning marks on the 75mm quite severe, which is why he had not used them on the high-end commercials he had then been shooting. I took the 50mm apart and found that all the stains inside were removable from the glass, an unexpected bonus. The cleaning exercise was fraught with one or two perils. The periphery of the glass elements is not chamfered and you need to beware of loose motes of glass coming off and getting into your polishing cloth. The fungus is now gone but there are a couple of faint scratches in its place, fortunately not critical. The assembly method for the lens is "different" and there are some contrary fitments, so do not attempt to force anything. The lenses appear to be largely handbuilt so don't expect to be able to swap barrel components The iris mechanism is not built into a self-contained module but is part of the centre barrel containing the centre and rear lens groups. If you decide to home-renovate, take care because all the little bits and pieces fall out and it is a monkey-puzzle to re-assemble, a three-hourer to nut out. I put both lenses on the SI2K expecting the resuilts to be quite mundane. These are old tech, small in physical size, in appearance more like old 16mm C-mount lenses. The lenses are idiosyncratic in function. I can't fathom why but I suspect the ergonomics share something in common with British car manufacture for the masses in the early 1950's and some of their aircraft cockpit layouts as well. Comfort and convenience for the human were not always part of the equation. They have ARRI wing-style focus handles but these are prettys which serve a different function this time round. The ARRI mount does not have the key or bayonet channel to lock the lens from turning in the mount. The focus is found, not by attempting to turn these wing handles, but by rotating the very front of the lens body. The wing handles in this instance are simply used to anchor the lens barrel from turning in the mount. It gets a bit confusing because the lens barrel has witness marks and the ring they are on appears to be able to turn but it is not free to do so and is part of the machining. To my surprise, the vision from these lenses is better than I expected. The image is crisp and the colurs faithful in spite of the marks on the front element of the 75mm. On the chart, they don't test quite as sharp as the CP Ultra T* lenses but are sharper than the Nikons except the 58mm Noct-Nikkor, 55mm Micro-Nikkor and 28mm Nikon f1.4 which they are on par with. The 862line resolution block "pops" nicely and the 1080line block shows a moire pattern which means the camera sensor sees the lines. There were of these a few among the ex-Boeing items listed on eBay a while back. If they are relisted they might be worthwhile at a cheap price but don't expect them to be flawless or easy to operate from go. FOOTNOTE: I can't post images as I now have Internet Explorer 8 and it won't open another web page like IE7 could. Here is a link to a frame. 25 points of sharpen were added to provoke artifacts. - there is a trace of CA towards corners. FURTHUR COOKE SPEED PANCHRO SERIES II ON SI2K FRAME 1 By Bob Hart On ExposureRoom |
Hdmi out and power supplies
4 Attachment(s)
Steve Rice's SI2K got a workout last weekend on a short feature "Trespass" being shot at night by film school graduates.
Power ended up being an issue for us. There was a big lighting tower but no access to mains power, one outlet restricted to RCD testing only. A second smaller generator was also being used for lighting so we were wary of transients and surges and stayed with batteries. First question. Given that the SI2K is essentially an XP computer, has anyone an opinion on whether a mains power isolator - uninterrupted power supply for computers would provide adequate protection for the SI2K on a small generator. Second question. I was seriously embarrassed during a recent home-visit demonstration when a potential client requested we patch the SI2K in to his huge great home-theatre HDMI screen and I was not able to do it. It seems that the ability to do so had disappeared with the upgrade to the latest firmware. I caught myself out badly as it had not entered my feeble brain to check. Previously I had just plugged one in and it had simply worked. So in great anxst, I have since ventured into the forbidden zone in the operating system and enabled the second monitor, a bit like crawling into the lion's cage to set a mousetrap on the floor to test the lion's forebearance and hoping to be out again and the gate locked before the trap goes off. I was lucky and things seem to be in good order. I find that the displayed image is underscanned inside a wide frame on the HDMI monitor screen. This is fine in the sense that things like booms in shot or vignettes when using a 35mm adaptor do not sneak into the frame undiscovered. However it would be better to be able to use the full display area of the HDMI screen for image alone. Does anyone have any advice on whether this is possible? I tried all the choices on the HDMI television itself and did not reach a happy ending. Any advice will be greatly appreciated. Yes. The images below are a bit grainy, shot lenses wide-open which is not ideal and gain added. |
Bob,
In answer to your first question, I would say the best way to protect the camera is running off batteries and let the charger run off the generator. But, what you ask is fine. A good UPS would protect the external power supply very well. What goes in on the 12V XLR connector should be clean. The second question is a bit more problematic. We had a number of customers who had difficulty providing a proper on-set video feed to the secondary monitor. To avoid overloading the CPU, we restrict this output to 1280x720 during recording. This became the default in the latest released version. What you tried - display of the clip player at a higher resolution when not recording - is OK. The clip player's deBayer algorithm is not ideal so a better preview would be using QT player or WMP using Neoplayer on another computer. I'm not sure what you meant by underscanned. The data in the recorded file should be at the resolution you set the camera to. Any aspect ratio issues should be addressed by the video card control software and the display setup. -Steve |
Steve.
Thanks for your advice. My personal preference would be as you suggest, use the batteries. Steve Rice has a five hour battery and two v-mounts good for about 35 minutes each. On the shoot the other night, there was a lot of standby time due to intermittent rain and we went way overtime. There was insufficient time before the next call to completely recharge the batteries. I tried running a 12v power feed from a car into the location which was in bushland however the cable run was too long and too much voltage drop. In regards the use of the term "underscan" I may be misusing it. The SI2K image which the HDTV displays is a smaller rectangle inside the available screen area. This may be due to limited choices available on the HDTV. I won't know until I test on another display. As long as a director can have a video split, it is all that matters. |
"I Belong To The Shadows"
For those with an interest in things Western Australian, here is a link to a rough grading test of some footage shot for Steve Rice's project by Jim Frater yesterday. These are not the better shots but ones which I copied to my computer. (See Below).
"I BELONG TO THE SHADOWS" - PRE-PROD PROMOTIONAL TRAILER ROUGH GRADING TEST. By Bob Hart On ExposureRoom The shakycam imaging of the first shot is intended to represent the view through a sniper's telescopic sight or binoculars and would have a vignetting effect added. Maxtor compact "One Touch" USB drives are proving to be a bit cranky. Out of three, one no,longer works at all, one seems to abort out of copying an entire directory and one is satisfactory. Two do not work at all on my XP computer or another computer at work, but are okay on another and also a laptop tested. The "My Book" style drives which require separate power seem to be fine, with no failures so far - touch wood. |
The only thing I can spot is that it looks like he's already hit the ground and died (and completely still on the feet/boots) by the time the food tray drops to the ground.
Apart from that, nice work. Andrew |
Bob,
Very nice. I would find it interesting to see the same shots after grading. Steve |
Andrew.
The clip I posted is only my own rough assembly of some of the shots. I think Steve's directorial intent is that the girl remains frozen until the officer hits the floor then drops the tray. The sniper has sent a bullet past her left ear. She has been expecting it but is still shocked. In retrospect, she should have reacted even if having expected it. I have not seen the other shots. These include a bullet injury painted into the officer's forhead, so all this is likely to have been covered. Steven. My "grade" as such, consisted of applying default look and bringing the whites up in the waveform. I am not the editor, who will likely work from the raw image. The lighting in the mirror shot was daylight spill through wide stable door and window plus one overhead camera lamp covered by a plastic cup. |
1 Attachment(s)
For those interested, here is the pole rig we used for the in-air shots a while back. In this instance it was used for in-car shots.
Camera operator, Steven Rice. Driver-Actor, James With. Pole front-end locates in a large foam wedge in the gap between windscreen and coaming (dash). The operator holds the other end. FOOTNOTE: Image changed for one of better quality. |
Hi Bob,
That's quite interesting. And I realised after typing that it was a rough edit for the purpose of grading. (slaps self on forehead) Actually, I thought what must have happened is that the girl was the assassin with a gun held under the tray ... which is why the baddie gets shot when he has opened the door and is facing the girl. I do appreciate the clips that you post. It's all very interesting. Andrew |
Due to the smaller cams being committed to other projects, I took an SI2K out to chase aircraft last weekend.
It was the full camera/recorder unit assembly. After using the lightweight cameras I found it a bit of a handful and was lagging behind the action or overshooting a lot more. I am inclined to think I was unaccustomed to the mass and a whole lot of reflexes have to be re-learned. Also, the Sigma-for-Nikon 50mm - 500mm f4 - f6.3 zoom is not a good choice for the SI2K It is not because of optical issues. The images are nice enough but the two-piece design of the lens is the achilles heel. It breathes, not the image but actually. When the front section moves out during a zoom movement, there is a lot of air sucked into the body of the lens through the mount. The lens picks up dust very quickly in its life and blows dust onto the sensor cover glass when you pull back to wide view. When you use it on an older Nikon FM2 SLR film camera, you may get dust blown into your eye through the viewfinder eyepiece or the doorseal gap. The Mini head operated remotely on the cable is the next test for ground-to-airs. |
Hey Bob,
The couple of times I've done in aircraft shots I've split the SI-2K - kept the recorder at my feet and had the smaller/lighter set up on the shoulder. It gave me more room to move in a small space but still had enough weight to help keep steady. |
Rohan.
Yes. That's what we did for an in-air scene. I thought about it for the ground-to-air but was concerned about the cable as I have a tendency to wind them up around the tripod when chasing aircraft overhead. |
Here is a link to a finished product, a music video which culminates in a car blow-up which was shot I understand with JVC GY cameras and the SI2K for 1280 x 720 slow-mo. I posted a link to the "kaboom" a while back.
YouTube - Slow Gun |
At play with the SI2K - Tropfest.
The 2Ks have been used on two 2009 Tropfest shoots so far over here. Both are pro-bono which means no money, just lunch, however it does achieve a profile of sorts.
If you look closely you will see the most bars---d elevated camera rig in the entire universe. Due to no budget but a request for high overheads and a in-tree shot, a Photax light stand was turned upside down, the shaft inserted into the spare panhandle hole on the Miller tripod and the camera head remoted, lackied and safety-gaffered onto the other end, then the light stand elevated. A dog to pan, tilt and trim focus but a good solution on the day. Let's see you do that with a RED or a Cinealta. Both shoots trouble-free except for the second when I hung a toe in a power cable just as the camera finished writing the file. The clips are still being recorded to files okay but something changed in the settings and I have confused them even more relating to time-code. So it is probably a reflash of the C:\> drive needed to fix it. Any hints as to how I may be mismanaging the timecode settings will be appreciated. The clips now do not lay out in sequential order, so the last clip is hard to locate for on-set playback - my mismanagement most likely. Here is a link to some behind-the-scenes stills of the most recent effort, worktitled "First Person Shooter" by Ed Love who also directed. It is a story of a teenager coming to grips with the death of his somewhat estranged father and their reconciliation when he comes back to put things right. MobileMe Gallery The stills were shot by the father of the teen actor on the most amazing mobile (cell) phone I have ever seen. It can surf the internet and it has a Garmin style GPS looking screen in it as well. |
2 Attachment(s)
Hey Bob,
Had the same issue on a music clip that I shot last weekend. Whenever the camera was powered down the windows clock would reset to a different time, meaning that the timecode would also reset. Thus the last shot wasn't the last shot when it came to playback & checking. A moment of great panic ensued before we figured out what had happened. I'm assuming that there is an internal battery that has gone flat but I haven't pulled the camera apart to find out. There is meant to be a new version of the camera software coming out shortly - I'll re flash the drive then. Love the high camera rig - it's what makes the SI-2K so much fun. |
Rohan.
Thanks for that lead on a memory battery. It never even entered my head but makes sense now. The camera has been at rest for a few weeks since I did the ground-to-airs at Serpentine and Murrayfield. Going back over the order of those clips, I also found them to be randomised. This camera body has to be one of the oldest of the current series body style as it was P+S Technik's demonstrator, so an expired battery makes perfect sense. It has that well-used look, all corners polished off and a few dents, which took me to the manufacturing method when I decided to do a bit of panelbeating. - Even those little side vents which look like pressed grilles are CAD machined. Our original scheme for the high shots was to use a boom pole but the soundman did not have a spare. Now a little hot head unit to go on a boom pole would be the duck's guts. I shall have to get on it. Nice shots in your clip. What lighting scheme did you use? |
I belong to the shadows pre-prod promo trailer
Here is a link to the unlocked trailer clip.
REVISED TRAILER VERSION By Bob Hart On ExposureRoom To the purists, - yes the forest shot is softer. It was shot on a Sony HVR-Z1P with AGUS35 35mm adaptor and 135mm f1.8 Sigmatel lens. To the audiophile, the 78rpm record recoveries were aquired via a modern Stanton electronic disco turntable with Ortofon 78 stylus and given some cleanup in Syntrillium Cool Edit Pro v1.5, which is still a favourite audio program for me. ( Cool Edit was aquired by Adobe and became Audition and now seems to have disappeared. ) As far as was possible, de-RIAA, then the original equalisation curves were applied. Parlophone recordings in particular come up very nicely if they are not too damaged. |
Tropfest 1 was locked off last night and will be submitted today.
The director Andrew Pheasant is very pleased with the ability of SI2K footage to be graded. His wife, an artist was moved to comment favourably on the tonal range. Tropfest 2 is offering a bit more of a challenge. The time limit is 7 minutes and there is 10 minutes of fairly tight assembly. Director Ed Love is anguishing over taking the scalpel to it and yet retain the pacing and emotional essence of the story. The vision looks heaps better than I thought I had any right to expect, given the limited indoors lighting resources - available daylight spill and two 450watt tungsten equivalent household CFLs in old Photax photoflood parabolic reflector lamps with gels. 10/10 SI, though our skills and resources do not match. |
At play with SI2K 3D in W.A..
First the sad news. The two shorts did not make the cut for Tropfest. 2010.
Second. We have been having a play with the SI2K system for 3D at its most basic, two camera heads on a bar, two recorder units mounted onto a plate which has a leg on it which goes into a vacant seat hole on the Elemack. The Mini heads and bar and just one VGA touch screen went on the end of a Movietech crane on the Elemack. The other touch screen stayed with the second recorder unit. The single screen was there for viewfinding. Control was via a handgrip run button and the sync box. Two quick and dirty versions of a clip rendered by me from Premiere Pro 2 are on youtube here :- YouTube - 3D TEST ANAGLYPH.wmv YouTube - 3D TEST 50LB.wmv One is double-view (crosseyed) viewing, the other an anaglyph render. There is very much a lot to learn about post with 3D. The camera heads are not matched, one is an early version (LEDs in row across top of rear), the other about 12 months old, (LEDs on rear in a row down right side. If you mount two recorder units near to each other like we did, take care to separate the airflows around them with a dividing panel between them otherwise they may ingest each other's hot air and overheat. This also happens with through-wall mounted airconditioner units. |
The Darling Films SI2K got a workout last weekend on a short feature shot over two long days last weekend, the worktitled "Two Minds".
The factory unit was hot and lots of water drunk. The camera temp went up to 72 degrees but the only problem encountered was a corrupt clip due to the camera being double-buttoned on button-off and was rolling when shut off at the power switch, not a good thing to do to it. |
Happy snap from "trespass" shoot
1 Attachment(s)
The camera op. is not me. The young fit little *%# ran around operating that thing all day and most of one night for three days. I was knucklewalking at the end of it.
If only I could slough off age and attrituion like the hide of a snake I would be happy. Alas I have to make do with being a "character". |
Happy snaps from "Two Minds"
4 Attachment(s)
A play with the SI2K in W.A..
On set stills from the short film "TWO MINDS' Producer: Andrew Napier Director" Damien Giglietta 1st AD: Johnny Ma DOP: George Davis Behnd the scenes pics ex-the facebook shot by Johnny Ma. Images 01 and 02. It might seem a chore but really only takes a moment. Always mark focus points with one of these and you won't go astray. Image 03. Nobody does blood, guts and brains seeing the light of day like FX specialist Freena Hamilton, so if you are here in the West doing a shoot and need all sorts of FX and make-up, give her a call. Image 04. A contradiction in terms, top gear P+S-built camera-recorder, Ex-Europe, top gear Chroszeil follow-focus, Ex-Europe, Budget Cine-city "Jumbo" mattebox, Ex-Chandrigagh India, all working as they should. FOOTNOTE: I just got to play with a beta of an updated DVR. For product confidence reasons, I won't go into details about the new feature set except to use the Aussie words which say something is very good - "it is the duck's guts". The following is probably not a fair comment to make and probably quite provocative but If the RED is not yet similarly featured and as turnkey user-friendly to feature production with light crews, it might be a case of RED being dead in bed. That is probably going a bit too far. The RED still has more pixels even if they are harder to muster down the pipe. I must drag my old no-name editing computer and its broken legged coffeetable stand down to the next shoot and start editing the 2K rushes on set to make a point, just because I can. |
