-   Shoulder & Handheld Supports (https://www.dvinfo.net/forum/shoulder-handheld-supports/)
-   -   Varizoom VZ-LSP & Vinten Vision 3 (https://www.dvinfo.net/forum/shoulder-handheld-supports/26869-varizoom-vz-lsp-vinten-vision-3-a.html)
Ed Baatz June 1st, 2004 03:07 PM
I have a Varizoom shoulder bracket (VZ-LSP) and have previously used it with a Bogen quick-release bracket and a Canon GL-1.
I am getting ready to buy a Vinten Vision 3 head and was wondering if there is any way to use the Vinten's quick release plate with the Varizoom bracket.
It would be great if I didn't have to remove the Vinten plate from my XL1S in order to screw the camcorder onto the VZ-LSP bracket...
Thanks, Ed
Ken Tanaka June 1st, 2004 03:10 PM
If the Bogen q/r plate is the same one I have on my Glidecam 2000 (and I suspect it is), the answer is no. It is not interchangeable with a Vinten plate. Close, but no cigar. It's just a bit too narrow and lock-slotted a bit differently.
Ed Baatz June 1st, 2004 03:20 PM
I don't have the Vinten Vision 3 head/tripod yet, so I don't know exactly what the Vinten quick release plate is like --- but I was pretty sure that it would not be anything like the Bogen's quick release...
What I am trying to figure out is if there is a Vinten quick release bracket that could be attached to the Varizoom VZ-LSP so that I could attach my XL1S (with the Vinten plate on it) directly to the Varizoom VZ-LSP bracket.
I'd guess that one option would be to remove the Vinten plate from my XL1s and then screw the Varizoom into the XL1S's tripod mount... But, if there is a Vinten bracket that could be attached and left on the Varizoom VZ-LSP it would make changing from using the tripod to using the shoulder bracket much easier and faster...
Ken Tanaka June 1st, 2004 05:04 PM
You can scan the Vinten site but there's no such adapter of which I am aware. I think you're just facing plate-switching.
Ed Baatz June 1st, 2004 06:30 PM
Since I haven't ordered the Vinten Vision 3 yet, do you know if Sachtler, Miller, Cartoni (etc) have a quick connect plate system that could do what I want?
Seems like something that would be MOST convenient, instead of having to remove the Vinten Plate and then screwing the XL1S onto the shoulder brace's bracket...
Maybe I am just asking for too much?
Ken Tanaka June 1st, 2004 08:08 PM
Off-hand, I don't know. But I seriously doubt it. I know I've never seen such accessories from Sachtler or Miller.
Be sure that you keep perspective on what's most important to you and your work. Accommodating a Varizoom shoulder brace at the potential expense of selecting the best tripod/head rig might, or might not, be in your best interest.
Ed Baatz June 1st, 2004 08:18 PM
Thanks Ken,
I agree... If it was THAT important to me I would just continue using my Bogen with its quick release system.
Maybe I will be able to have a custom bracket made that will fit on the Varizoom shoulder bracket and accept the Vinten slide plate? A custom-engineered bracket might even cost less judging by the price of many other Vinten accessories... <grin>
I'd just want to make very sure that a custom bracket held my XL1S securely!
