Shoulder Mount EX Next? 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old May 19th, 2008, 03:35 AM   #1
Living on the other side of the planet means that to buy a shoulder mount for my EX-1 from B&H Photo, or any of the other suppliers mentioned in these forums would cost me an arm and a leg, and that doesn't include the shipping charges. So I made my own. All up, including all materials and cost of bending shoulder bracket and powder coating, the mount only cost me $100 (and the aluminum was free - found in the engineering shop bin).
Shaun R Walker is offline   Reply With Quote
Old May 19th, 2008, 04:24 AM   #2
Great work Shaun. I am just up the road in Newcastle. I have the cheap Indian shoulder mount, but yours looks better.
Graeme
Graeme Fullick is offline   Reply With Quote
Old May 19th, 2008, 04:41 AM   #3
Excellent, Shaun.
This is an example of what I meant in another thread, writing about shouldermounts / shooting styles that allow using the EVF instead of the LCD, which - in very bright sunlight coming from behind - can be completely useless due to reflections.
I'm using my PAG Orbitor and/or "El Cheapo" shouldermounts in exactly the same fashion (the latter with Manfrotto QR adapter mounted directly on the main pedestal, with the support removed). The extra bonus being that the camera CoG is closer to your body, thus feeling even lighter.
If only the EVF was of the Xtrafine resolution, as found on the Z7!
PS. Serena and Mike, do you know what I mean now?
Old May 19th, 2008, 04:54 AM   #4
Thanks Graeme. We should meet.I am looking for other EX-1 operators for a project I am working on on the Coast
Old May 19th, 2008, 06:31 AM   #5
Images: 3
Piotr, Of course I know what you mean. Shoulder mounts have been around for a long time. I used them shooting 16mm back in the 70s. And since. There are many designs and I doubt that you can imagine a shooting position I haven't used. Unfortunately you don't understand what we've been telling you, which is possibly a Polish/English translation problem. The LCD with hood and eypiece can be used on a shoulder mount, whether the sun is behind you or where-ever. But you are stubborn. You will note in Shaun's photo that he is looking at the LCD.
Old May 19th, 2008, 07:36 AM   #6
Wearing a large sombrero might fix the problem.
Old May 19th, 2008, 07:55 AM   #7
You are right Serena. I have a Petrol hood on the LCD. I thought about making the mount so that I could also use the EVF, but it's such a bad monitor I never use it. Piotr, I have found that if I have sunlight hitting the LCD whilst on the sticks I position my body to shield the viewfinder (or contort my body in such a way that I can tilt the viewfinder downwards and still see it)
Old May 19th, 2008, 09:51 AM   #8
Great work! Just pad that shoulder!
Mike Stevens is offline   Reply With Quote
Old May 22nd, 2008, 02:52 AM   #9
Could you please send more pictures. I will definitely try to do the same thing !
DoP, Video/Camera assistant
http://www.lecentre.net/blog
Sebastien Thomas is offline   Reply With Quote
Old May 22nd, 2008, 03:42 AM   #10
Hi Shaun,
Pete McMurray has an EX-1, I'll let him know your on the lookout.
Welcome to DVInfo - small world
Cheers - Paul M.
www.perbenyik.com
Old May 22nd, 2008, 05:09 AM   #11
Originally Posted by Paul Mailath View Post
Hi Shaun,
Thanks Paul. Already got him in mind.
Old May 22nd, 2008, 05:10 AM   #12
Will do Sebastie. Just waiting for the next few days work to finish then I will post some more photos with more details of the build
Old May 22nd, 2008, 05:14 AM   #13
Hey Shaun,
I have been looking at building the same thing for the Z1.
How does it handle? can you use the eye piece? What about getting on to a tripod in a hurry?
Look forward to more photos.
Cheers
Simon
Old May 22nd, 2008, 05:52 AM   #14
The problem with using the eye piece on shoulder mounts without any front support is that - since the camera needs to be offset to the left so that the typical, handycam-style EVF can be put against your right eye socket - the created moment of gravity will make it unstable, and put an even greater burden on your right (supporting) arm.
Therefore, when I plan to use the eyepiece, I am using either the PAG Orbitor, or my (modified) "El Cheapo" shoulder support. Both have front support against your waist belt or abdomen. See here:
http://www.dvinfo.net/conf/showpost....9&postcount=17
The other question is easier - it's enough to mount a QR plate adapter on the shoulder mount, using the same plate as your tripod.
Old May 22nd, 2008, 01:27 PM   #15
Hi Shaun
I might be available depending upon the project and timing, although I'm in Bowral
Send an Email
Cheers
Peter Donaldson is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
