-   Shoulder & Handheld Supports (https://www.dvinfo.net/forum/shoulder-handheld-supports/)
-   -   My new DIY Shoulder Mount (https://www.dvinfo.net/forum/shoulder-handheld-supports/105064-my-new-diy-shoulder-mount.html)
James Stone October 5th, 2007 12:09 PM
Hello folks,
A couple of years ago, I made a should mount that was made of metal pipe. It worked okay but it was a tad heavy. So on the insistence of my co worker, I decided to take the plunge and build a new one out of aluminum.
The whole thing cost about $90.00 US. Here's what I used and where I got them.
1 piece @ $16.34/piece
Aluminum 6061-T6 Bare
Drawn Tube
0.625" x 0.125" x 0.375"
Cut to: 24"
1 piece @ $20.99/piece
Aluminum 6061-T6
Seamless Tube
0.875" x 0.125" x 0.625"
Cut to: 36"
total with shipping about $41.00
(6) Aluminum split shaft collars from Mcmasters & Carr = $32.00
4' of 3/8" Aluminum rod from Orchard supply hardware = $7.00
3 qtsf of foam padding from OSH = $3.50
1 can of Duplicolor MetalCast Blue "Anodized" spray paint = $7.00
1 can of Black Plasticoat from OSH = $7.00
(4) Aluminum electrical lugs to use as mounting brackets = free from work.
I was able to save money from by getting the aluminum sheets from work and cutting them down to size there. I also had my friend weld the pieces together at work. If I were to do it again, I would get a drill press and drill/tap the pieces together instead of welding them.
So after three weeks of using company time to put it together here's what I came up with. It took a lot of polishing to get the shine.
I just finished it last night, so I haven't had a chance to field test it yet. Let me know what you guys think.
James
http://members.dslextreme.com/users/...unt/smfront.jp
http://members.dslextreme.com/users/...upper-back.jpg
http://members.dslextreme.com/users/...ercarriage.jpg
http://members.dslextreme.com/users/...ount-mount.jpg
http://members.dslextreme.com/users/...lower-back.jpg
http://members.dslextreme.com/users/...ount-front.jpg
Peter Ralph October 6th, 2007 09:00 AM
nice job - I think you copied the Birns and Sawyer image2000 unit?
What camera are you using it with?
James Stone October 8th, 2007 09:10 AM
Hey Peter, Yeah the Image 2000 was my inspiration for it. I just couldn't justify the cost of a new one. We plan on using a DVX100b and an XL2 with it.
Peter Ralph October 8th, 2007 01:31 PM
I use an image2000 with an XLH1 - works great. I dont have any use for the handles though. I'm thinking of making another one with just the shoulder rest and a fixed position tongue sticking out the front custom fit to the XLH1 and a quickrelease.
thanks for the hardware links - I'm always imagining things I want to build....
Edward Carlson October 17th, 2007 07:29 PM
1 Attachment(s)
Very nice. I am also planning on making one. My idea is inspired by the Birns and Sawyer model, too. My version will probably be put together with drilling and tapping because I just learned how to (after breaking two taps!) and because I don't have any welding equipment. I like your tubular design for the hand grips, so I'll probably change my design to that. Love the blue anodized look, I couldn't even tell it was spray paint!
P.S.: My design is attached.
James Stone October 19th, 2007 11:28 AM
2 Attachment(s)
Ok here goes version 2. I bought myself a Craftsman powder coating gun and re-finished it. I also had to trim some off the shoulder piece to make it fit in the toaster oven. I also but a bend in the handles so that they flare out a bit. My friend is field testing it today on a shoot so I'm sure V 2.1a is right around the corner. Oh and the nut in the top is just keeping the mounting screw there so I don't loose it.
James
Martin Catt October 20th, 2007 05:13 PM
Looks good from this distance. If you're married, I'm sure your wife appreciated you using the toaster oven, and not the big one in the kitchen.
Martin
James Stone October 20th, 2007 07:31 PM
finance, doesn't know about the powder coat gun and I made sure to buy my own toaster oven. The thought did cross my mind to use the house one, but I really don't want to tempt fate. Plus I'd have to bake like five cakes just to cover the smell.
James
Martin Catt October 20th, 2007 07:36 PM
So, I have to ask: how much was the powder coat gun? It sounds like something I should own.
Martin
James Stone October 20th, 2007 07:42 PM
I got it at a flea market for $60.00. It came with a half bag of satin black and a bag of red.
I was about to get one off of Ebay, but was out bid. I've seen them go for about 90.00 there. The toaster oven I got for 25.00 after my 20% off coupon from Beds, Bath and Beyond.
