-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   Anybody use China Balls regularly? (https://www.dvinfo.net/forum/photon-management/95879-anybody-use-china-balls-regularly.html)
Noah Posnick January 3rd, 2006 05:18 PM
Battery operated china lantern
I have a few scenes at a beach during dusk/night. It's going to be somewhat of a run and gun shoot and I can't use a generator. I considered using a mini-flo kit, but, for the scene, i prefer the light quality of a photoflood in a chinese lantern. Is there any way I could hook one of these up to a battery belt (it would be easy enought o rent that)? Or maybe there is another light that is available to rent in the NYC area that is already battery powered that I could just stick inside a china ball? The problem is that most battery operated lamps i've come across are directional, which is not ideal to put inside a chinese lantern. My shoot is next weekend so any help would be much appreciated. Thanks!
Marcus Marchesseault January 3rd, 2006 05:52 PM
I've done this exact thing on the beach in Waikiki. Get a standard Chinese lantern with a regular household "Edison" medium screw-in socket. Put the brightest fluorescent bulb (or using a "y" adapter, two bulbs) you can find in it. I have found that the largest bulb I can find that fits in it is a 65W compact fluorescent from naturallighting.com. I have found up to 40W compact fluorescent bulbs at the hardware store. Use a DC-to-AC inverter with your choice of 12V source and you have an efficient source that most video cameras can work with. I used deep-cycle car-style batteries and ran the set for about 8 hours. A 65W fluorescent on a battery belt will probably only run for a little over an hour. A bright tungsten light will only last for several minutes on a belt and about an hour on a car battery. Your only other choice would be a small HMI light. I seem to recall there is a battery-belt operated 200w version called something like "sun gun".
Depending on what you are doing, you could also use a standing diffusion frame near your subjects and hit that with a directional source powered by big batteries. Chinese lanterns don't have any control, but they are good if you need to move them while shooting the subject. I doubt you could do better in this situation than a fluorescent considering the short battery life of a tungsten.
Mark Sasahara January 5th, 2006 11:16 AM
If you get a globe for a sun gun you just need to find the right base for it and wire it up to your battery. Mine uses JC12V __ H20 bulbs with G6.35 base. Fill in the wattage where the blank is, I think the choices are 20W, 30W, 35W, 50W, 75W, 100W. Any decent electrical supply should have the G6.35 bases and a good photo store will have the globes.
The nice thing about Canal Street here in NYC, is that's mostly Chinese owned businesses, so the electrical place I go to has a few photo type bulbs and electrical stuff, plus China Balls of various sizes and colors.
Check some of the manufacurer's catalogs, GE, Sylvania, and see what other options you have for 12V, 24V lighting. I noticed on B&H's site, that there is a 300W 24V globe. I think you'll also need low voltage wire as well. Just be sure you've got plenty of battery power. Bescor Batteries are pretty good and not too expensive.
Go to a website like B&H and look at what's available for on camera lighting and power, that will help you with your choice of battery and connector. You can probably get a cigarette lighter adapter, or four pin XLR. Perhaps buy a cheapo camera light and remove the reflector, so that you can mount it to a boom, or monopod and then have it be bare bulb.
Walter Graff January 6th, 2006 01:43 PM
You can also buy 12 volt type A lamps that work better than flouros. Just like putting in a regular light-bulb in a lantern. Look online. RV stores sell them as do boat stores like Boat USA
Sean McHenry January 6th, 2006 03:52 PM
Make sure you have enough current available in whatever battery you use or you will find yourself white balancing a lot toward the end of the battery life. The light will get progressivly warmer as the voltage drops.
I have shot in the field using a car battery (in the car) and a voltage inverter to get normal 110VAC for smaller lights. Watch your available current ratings if you do this.
Sean
Noah Posnick January 6th, 2006 10:23 PM
Thanks everyone for your help. I'm going to probably rent a 12/24v block battery. I'm going to try and assemble the light in the next week or so. I'll let you know how it goes. Thanks again. I'm surprised there isn't a unit like this in production/ available to rent.
Bob Grant January 22nd, 2007 05:05 AM
Anyone used 'China Balls' from Jem Lighting?
Check them out here:
http://www.jemlighting.com/
The fabric covered ones look more durable than rice paper.
Mark Sasahara January 22nd, 2007 09:56 PM
Haven't used them, but they're as good or better than the Chimera, depends on what you're doing. There's an actual cage which you can clip gels to. I've had to make rather elaborate bailing wire cages for my paper lanterns. Even a 250w bulbs gets hot enough to melt 'em pretty quick.
I have been using paper lanterns and a few lamps stems I made myself and they've held up pretty well. I think one of Phillippe Rouselot's assistants has a page on how to make the stems. That's where I got the info. Been trying to find the link, but not finding it, sorry. I think Phillippe uses the Jems, 'cuz he loves the light China balls make.
I also have a Chimera 20 inch Lantern that's pretty nice. Had that on the end of a Gitzo monopod that followed the camera around during a long hand held sequence.
Going to Gaff for a friend of mine and we'll use china Balls to light a gala event in a short film. That's a pretty easy way to light a large area. We both have a bunch from a job we did together, last year.
If you take care of them, the paper ones will last a while. Course a nice heavier guage metal and fabric one will last longer.
The nice thing about paper is you can spray paint it to change the shape of the light's reflection and color.
James Carver June 5th, 2007 10:27 PM
i've been recently reading about the use of china balls and wanted to know exactly what is used to hang them? do they come with a stand? every website that sells them or has photos dont offer a stand. or are you forced to hang them from the ceilings with whatever you can or something?
Jeff Anselmo June 5th, 2007 11:09 PM
Hi James--
China balls have widespread use because of their versatility and their relative inexpensiveness. We've used them in low budget indie productions, student films, reality tv shows, etc. I've mainly seen them used with practicals (regular house bulbs, 100w and lower) for ambience, fill, and even key light situations.
When I was a PA in Hollywood many lifetimes ago, I was told to "hang up" several china balls from the ceiling inside a very plush, very expensive four star hotel room (where was the gaffer? where was the electric dept.?). With nothing but gaffer's tape, I hung four of them from the ceiling, about three feet apart. The cords were gaffed tape to the walls (partially hidden by curtains), so they didn't cascade from the ceiling. The cameraman/d.p. apparently didn't mind my "set up" as they shot their piece the next day.
But to answer your question, no there isn't a stand that comes with a china ball, at least not when we bought them from Ikea. Good thing these things are "light" enough (pun intended :) that you can hang them using gaff tape.
I've also seen china balls safely hung from c-stands with arms.
Best,
--Jeff
Charles Papert June 5th, 2007 11:10 PM
Yes. The nice thing about these units is that they are so light, so they can easily be suspended for ceilings that would not be able to handle many other types of lighting fixtures. Also you can mount them on a boompole (or makeshift version of same, like a broom handle) as a moving fill light.
While they are still popular for certain applications like lighting people around a round or square table, ambient lighting in large interiors etc. they have the drawback of being a bit indiscriminate, with the light splattering everywhere. Not great for small rooms as a result. It is helpful to be able to skirt them (black material hung around the ball that is scored so that it can be pulled up in sections as desired) to control the output.
About 10 years ago when china balls were at their height of popularity, I was doing Steadicam on a fairly well-budgeted music video. The young DP was rather full of himself, definitely working the "flavor of the month" vibe. For a night tracking shot he rigged a large ball off a pole above the camera, and then spent half an hour personally attaching bits of duvetyne and blackwrap around it to control the spill until literally one square foot of light remained. I may have remarked that he had re-invented the 1k Ziplight, but probably not within his earshot. In any event, it started to rain and most of the black material fell off the ball by the end of the shot. I was privately rather pleased.
James Carver June 6th, 2007 07:38 AM
man this is exactly what i needed to know guys thanks. that is a great tip about mounting it on a broomstick handle and having somebody hold it.
so ikea sells them?
what black material do you guys recommend that is best for controlling the light spill and won't catch on fire if that thing gets to hot?
also should i be looking for the paper china balls or the nylon china balls?
Richard Alvarez June 6th, 2007 08:02 AM
Well, any lamp hot enough to catch the paper on fire, is too hot. Most of the china balls come with a recommended wattage, I try not to push it too far, using common sense.
Yeah, Ikea sells them in a couple of sizes.Very inexpensive. I've got three of them in my closet. One I've been using for a couple of years, and two I haven't opened yet. Note that they have openings in the bottom. I usually cover these openings with a piece of baking parchment.
You can mask the sides of the balls with Duvateen, or Blackwrap. Blackwrap has the advantage of being malleable - so you can shape it a bit. One of the things about masking the balls if you are also MOVING them, is they tend to rotate a bit... making your masking pointless.
Yes, mount it on the end of a boompole, broomstick, painters pole, whatever... and you can 'hang' it over a person walking along in the 'dark'.
If you visit this link
http://vids.myspace.com/index.cfm?fu...oid=1938959903
You can see the procedure being used to supplement the light from a hand held lantern in our short film "After Twilight". (It's about halfway through the podcast.)The light on the end of the boom is actually a hard practical, but the procedure is the same. The practical has a piece of Black Wrap on the back of it to cut down on spill.
You can also see a good example of shooting 'the poor mans process' - a 'moving night interior' in a taxicab. Shot inside a small studio.
Bob Hart June 6th, 2007 08:52 AM
Some examples of the home-innovated chinese lantern, gaffered to a broomstick with a loose cord and plug swinging and dragging on the ground are an electrocution or fire risk searching for eventual fulfillment.
Large white translucent plastic outdoor spherical porchlights or top of column lights are a passable substitute, not quite as diffuse but much more robust and electrically safe.
For safety, the boom is a length of power PVC tube, outdoors grade lamphouse, outdoors switch and power connection are attached into weather resistant junction fittings glued onto the boom.
Use a calico shopping bag around the porchlights when not in use to stop them going all scratchy and brown. A good scrub with automotive cutting compound and a polish will restore them when they do become grubby.
More expensive than a paper lantern, but safer.
Heiko Saele June 6th, 2007 10:32 AM
1 Attachment(s)
The Austrian company airstar makes professional china ball lanterns which seem to be floating like a helium balloon. They are used for sporting events like the biathlon world cup as well as film productions.
They look really cool and the light is beautiful but I guess they're a little more expensive than a 2.99 china lantern ;)
Brian Standing June 6th, 2007 10:39 AM
I found a supplier of collapsible nylon Chinese lanterns -- more durable and less flammable than paper -- that are still pretty inexpensive. The wire bracket that holds the light socket and expands the lantern is pretty flimsy, though -- I had to reinforce it with gaffer's tape. I'll try to find the link and post it here.
Also, consider using daylight-balanced compact fluorescent bulbs rather than tungsten, to reduce the fire hazard.
Peter Wiley June 6th, 2007 12:29 PM
I have one of these latern lock lights and it works very nicely. Fits c-stand.
http://www.lanternlock.com/
Simon Hunt June 9th, 2007 08:25 PM
Check out Chimera Lanterns. More expensive than paper, but much safer. I have the 20" version and it's quite good. It comes with a Velcro-on cover for 1 or 2 sides. Light weight enough to be attached to an extend-able painters pole for "walk-and-talk" shots.
http://www.chimeralighting.com/
Andzei Matsukevits June 10th, 2007 01:33 AM
1 Attachment(s)
shooting music video...
Dan Keaton June 10th, 2007 06:22 AM
The AirStars are indeed helium balloons with professional lights installed. They come in Tungsten and HMI models.
These use a significant amount of helium, so a large tank is necessary for a shoot.
Their flying height is limited by the weight of the electrical cord. In most cases they will fly high enough to do the job, but do not expect to fly them to heights of 200'.
Helium is not cheap. Once they are filled (expanded) they become more than 6' in diameter, so storing them overnight in a small trailer is not really feasible, unless you partially deflate the balloon.
Last November a very large hot dog bun shaped one was used on a movie set in our area. It gave a very nice light to a large outdoor area. They used two large Mambo Combo c-stands to hold the balloon. It got pretty dicey when we had some unexpected strong gusts of wind.
Brian Posslenzny June 15th, 2007 10:14 AM
One thing I've found that works around a moving China ball, and the skirt always rotating:
Attach a piece of fishline to the top of the ball, and the other end to the boompole. Now it's not going to rotate on you. Maybe use a #1 clip on the ball, and gaff tape on the pole.
John Jay July 28th, 2007 05:49 PM
I often wonder why people put the lamp inside the 'china ball' - read 'ikea $5 regolit' - chinese lantern?
I have had loads of success externally firing two snooted 1k OF - or 800 reds into them - diametrically opposed or to taste
best soft lighting around :)
regarding earlier post - tethered helium filled party baloons hold 'em up nicely too
they also work nice for off camera flash for stills work
Charles Papert July 28th, 2007 09:15 PM
That'd work. It depends on what kind of lighting you are doing, and how many directions you need to be able to see on a given shot and/or over the course of the shoot. A china ball hung from the ceiling with a well-dressed cable will deliver 360 degrees of light and shooting flexibility, while the bouncing method might require moving the heads if they show up in a given shot. For a dinner scene for example, you would have the flexibility to shoot anywhere around the table without having to relight with an internally-lit china ball.
John Jay July 29th, 2007 04:19 AM
Hey Charles, how you doin', I haven't been on the board much lately.
Another tip (thank God for Ikea), concerns the tall cylindrical white lampshades they have - great for snoot bouncing.
Charles Papert July 29th, 2007 08:32 AM
Doing good John, what's kept you away from us...?! Busy shooting, hopefully?
John Jay July 29th, 2007 10:22 AM
Ah yes work work work :)
Joyfully anticipating the arrival of my new Tosh 1080p 24p LCD TV, the Sanyo Z3 projector had to go too expensive on the lamps.
