Arri Arrilite / Fresnel Mini Kit need softbox
Hello,
I order Arri Arrilite / Fresnel Mini Kit with 2 Arrilite 600 & 2 300 Watt Fresnels, Bulbs and Accessories, 1,800 Watts, 120 Volts. ( http://www.adorama.com/AR571993.html...ri&item_no=125 ) And I don't know what softbox and speed ring will work with the Arrilite 600 & 2 300 Watt. links would be nice! Thaks for your help. |
Look up chimera at either Adorama or B&H. They'll have full listings for whatever you need although I personally find B&H's site a little easier to navigate. A soft box for the 300s is going to be wasted, concentrate on the 650s.
Chimera's site (http://www.chimeralighting.com) has a complete list of speedrings and lights they fit on.
I don't know that I'd say a softbox for the 300 is a total waste. An Xsmall on a 300 is nice if you need a little soft light close to talent. You'll certainly use a softbox on the open face 600s much more often. |
Thank you!
I have never use this lights so I was not sure if the 300 arri would give more light then the Lowel lights at 300W.
Thanks for the help. |
