-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   $3.25 DIY Snoot (https://www.dvinfo.net/forum/photon-management/85028-3-25-diy-snoot.html)
Bill Hamell January 28th, 2007 06:28 PM
$3.25 DIY Snoot
4 Attachment(s)
I looked at getting a snoot for an Altman 300-L, while I will usually pay the freight for a quality item $80 was a bit much for some sheet metal.
This is my first attempt at tin knocking so I learned a lot the next one will be better.
First I needed to redesign the concept of the snoot to fit my abilities and available materials. I decided on a rectangular five side box to be held in place by the barndoors.
For the 300-L it worked out to be 6”x 8” in size I decided on 1” sides. I bought a piece of 22ga. mild steel 8”x 24” for $6.50 out of this I can get two snoots. I cut an 8” x 10” piece out of the stock and marked 1” lines along the sides. On the short sides I cut along the lines from the end to the intersecting line. Bending the short sides first then the long sides allowed the corner to form, after a little tin knocking I drilled a 1 7/8” hole in the center.
That’s my $3.25 snoot. Later I will rivet the corners to make it permanent.
Bill
Scott Ellifritt January 28th, 2007 11:04 PM
Necessity is the mother of invention! :)
Bill Hamell January 29th, 2007 08:09 AM
My thoughts exactly. :-)
Michael Carter January 29th, 2007 02:15 PM
Why not try and copy an actual snoot?
(Or a "top hat" as they were called back in the day). Mine slides into the gel frame carrier; they're a flat piece of sheet with a tube attached, so the flat end is against your light and the tube sticks out. Could be a lot easier to do?
(I didn't make mine, but man, looks like a sheet of metal and some stovepipe would do...)
Bill Hamell January 29th, 2007 02:36 PM
Simply becuse it was easier and produced the same effect.
Bill
Bill Ball February 1st, 2007 07:43 PM
For my 6" frensels I took a large coffee can and pop riveted onto a square of sheet steel from home depot. Spray painted it black. $5 and 30 minutes later I had a snoot. You do have to curl the edges of the sheet steel a bit so it fits in the gel holder of the light snuggly.
Bill Hamell February 2nd, 2007 06:36 PM
Another good idea, it takes about 10 minutes for me to make one of these.
Chris Sinista February 2nd, 2007 10:58 PM
hey it works right ?
