-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   how to light a room at night (https://www.dvinfo.net/forum/photon-management/72282-how-light-room-night.html)
Jack Major July 25th, 2006 08:46 PM
how can i light a room to make it look like it isnt lit as if some just woke up in the middle of the night and walked out to the living room. Im shooting on a sony hvr a1u.
-Jack
Mike Teutsch July 25th, 2006 09:02 PM
-Jack
Very indirect, maybe from another room, like the light is drifting in. How do you want it to look? Maybe the TV was left on?
Mike
Jack Major July 25th, 2006 09:32 PM
i guess im wondering how many foot candles is a computer lcd screen with a white internet page up?
Mike Teutsch July 26th, 2006 06:26 AM
Unless he is sitting directly in front of it----not enough.
K. Forman July 26th, 2006 06:45 AM
The PC may not be enough to light for a video shoot, but if you walk through the house at night, you know it gives you enough to avoid most obsticles. All you need to do is show the glow coming from the screen, and you have introduced a believable lightsource for the viewer. You are then free to use other lights to fill in more detail. Just watch for reflective surfaces giving away your set lights.
Glenn Chan July 26th, 2006 09:33 PM
One way:
Get a fairly powerful light (1K/2K tungsten, or 575W HMI) and gel it very blue. Bounce it off the opposite wall- this will give you blue fill / ambient light.
If talent is sitting in front of computer, the LCD should give nice soft light.
Use other lights to add some shadows/patterns on the background walls. Blinds patterns or tree leave patterns would be motivated... although you can use stylistic slashes of light too.
Jack Major July 27th, 2006 01:31 AM
thanks guys will do.
Cole McDonald July 27th, 2006 03:37 PM
if you're on the ground floor, you can shoot a light through the window (gelled blueish...or a blue party flood) to simulate moonlight - low angle, hard shadows. then a warmer light from in side and lower the brightness and raise the contrast slightly in post. Over light and under expose.
