-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   My First Flicker Box (https://www.dvinfo.net/forum/photon-management/67350-my-first-flicker-box.html)
Bill Hamell May 14th, 2006 01:07 PM
I needed to add some "fire" to a scene so I built a flicker box it has four outlets three that flicker all the time and one can be set to flicker to just to stay on.
I'll add a master swich and a fuse holder to compleate the project.
Bill
The box
http://cinebydesign.net/film/flicker-box.jpg
The inner works
http://cinebydesign.net/film/flicker-box-1.jpg
Jesse Redman May 15th, 2006 08:34 AM
Schematic?
Can you share the schematic?
Bill Hamell May 15th, 2006 01:15 PM
Jesse,
I would if I had one; I wired this as I went along.
Basically all you are doing is adding a fluorescent starter on the line (load) side of the circuit. This is what causes the lamps to flash. I remember seeing a web page that had a diagram if I can find it again I will post the URL.
Bill
Doug Spice May 18th, 2006 04:47 PM
I'd also be interested in seeing that.
Bill Hamell May 19th, 2006 11:45 AM
Ok, guys here's the deal, I am finishing up the schematic when it is done I will send it to a friend to check it. Give me the parts I can build it, but ask me to draw it and maybe I'll get it right. If he says it is correct then I will post it.
Bill
Bill Hamell May 20th, 2006 04:01 PM
1 Attachment(s)
The usual disclaimers apply this is for educational purposes only if you make one of these I am not responsible for any damage or injury that occurs.
Jesse Redman May 20th, 2006 09:38 PM
Bill,
Thanks for the schematic. I will be buidling one.
What types of lighting do you connect to this?
Bill Hamell May 21st, 2006 02:12 AM
Jesse,
You would use regular light bulbs up to 40 watts one per outlet.
Bill
Jesse Redman May 21st, 2006 10:58 PM
Thanks again. You've been a great help.
Bill Hamell May 22nd, 2006 01:47 PM
You are welcome, let us know how you made out.
Don't burn the house down! :-)
Bill
Bob Grant May 22nd, 2006 07:07 PM
Bill,
just a thought here you might like to try.
Wire another lamp accross the fluro starter. This means when the starter is open circuit two lamps are in series and will be pretty dim. When the starter closes one lamp goes out and the other goes full brightness.
Advantage is reduction of surge current into the lamps increasing their life and probably help the starters themselves last longer.
Bill Hamell May 2nd, 2007 06:09 PM
Thought I would bump this thread.
I used the flicker box in a recent film, you can view the trailer and see the flicker box in action here...
http://www.dvinfo.net/conf/showthread.php?t=92935
Bill
