-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   How to mount a light on the ceiling? (https://www.dvinfo.net/forum/photon-management/53939-how-mount-light-ceiling.html)
Ben Whitley November 6th, 2005 10:06 PM
In watching the "behind the scenes" clips on movies I rent, I see that, many times, flourescent fixtures are mounted in the corner where a wall and the ceiling meet - like above a window where crown molding goes. Anyone know how this is done? I know they don't use stands. I always have a need to mount lighting in a ceiling corner.
Richard Alvarez November 7th, 2005 07:51 AM
Scissor clamps usually.
Ben Whitley November 7th, 2005 08:29 AM
Interesting... how do scissor clamps hold a light in a corner?
Matt Irwin November 7th, 2005 01:49 PM
Scissor clamps with an attached baby pin are used with acousting drop-ceilings (like you see in offices, etc.). You just have to make sure that the clamp is close to one of the wires connecting the drop-ceiling to the real ceiling.
There are also suction mounts with a pin that can hold lightweight units. If you're not going to be seeing the ceiling there are always wall spreaders...
The only problem with the suction cups is there isn't necesarily going to be a point to attatch a safety cable to the unit.
George Odell November 8th, 2005 02:35 PM
There is also a rig made from a wide putty knife that has a 5/8" spud coming off the handle. You jam the blade between the molding and the plaster ceiling and hope it stays put.
Guy Cochran November 8th, 2005 02:47 PM
The Lowel Space clamp does a great job at hooking onto doorways, doors and anything else you that you can hook onto. I wouldn't put it on ceiling tiles with a heavy light though and you'll need to be careful about "indenting" soft wood and plaster - it has a mighty grip.
Check it out at http://www.lowel.com/clamps.html
Charles Papert November 8th, 2005 03:52 PM
Often 2x4's are mounted above the molding via clamping hardware (like a wall stretcher but without the potential for collapse that the spring-loaded version presents) and then a plate is screwed into the 2x4. Kinos are not the heaviest fixture but you must assure a positive support for safety--I certainly wouldn't trust them to a putty knife clamp.
Peter Rummel November 13th, 2005 09:04 PM
A way to use flo's on walls or ceilings where there's nothing to attach them to or no room for a fixture is to just gaffer tape the tubes to the surface. A local gaffer showed me this trick where we had a scene with 2 actors across a counter with very low ceilings. The director wanted a wide shot with a dolly move. There was no room for a fixture, and bouncing light off the ceiling would have ruined a moody shot. We took the tubes out of a 4' Kino and taped them to the ceiling above the counter, between the actors. It was quick and looked great.
Charles Papert November 13th, 2005 10:57 PM
Mmm, indeed Pete I had forgotten that. You can also run some 2" paper tape or blackwrap off the ceiling to act as a cutter of sorts to prevent spill all over the ceiling on one or both sides.
Mark Sasahara November 16th, 2005 01:05 PM
Use Permacel Paper tape. The matte black stuff is best. The semi matte, that says "PH Neautral" inside on the paper core is not the right stuff. It should just say Permacel. I think it's the #743 black paper tape.
I have taped up just the Kino lamps and harness to the ceiling. I just check it every now and then, to make sure that it's not peeling off. You can also make a sort of barndoor with the paper tape too.
Hang Duvetyne teasers, also with paper tape, to help control where the light goes, or doesn't go.
Never use regular gaffer tape on walls, or ceilings, you'll pull the paint and part of the sheet rock off, if you aren't careful. You should also be careful when taking the paper tape off too. If possible tape to painted wood. Never tape to wallpaper, you'll tear it right off, or just the top surface, which is impossible to hide.
Tabbing tape, in general, is helpful and makes pulling it off easier.
