Buying a major light kit. Need recommendations.
Hey guys I am looking for a continuous light kit for shooting video of models and independent filmmaking. I have 2k to spend more if the money is worth it. I want at least a 3 point lighting with key, omni, tota. I also want stands that are very stable for film people traveling between the stands all the time. Also important for me is great dimming for small locations.
Any recommendations? |
I would suggest you pick up a set of Arri's. http://www.bhphotovideo.com/bnh/cont...hType=search"]
This is a very nice general purpose kit that I have. Arri's are really durable. I also have a set of Omni's from Lowell but I find those to be a lot more fragile. You should also pick up a few (two or so) soft banks from JTL. I've found JTL to be a really good value. Well built and reasonably priced. http://www.jtlcorp.com/green/softboxes.html |
Personally I'd go with a combination of Arri Fresnels, and a Dedolight 150w w/Projector lens for lighting backgrounds (with the small metal gobos) to give the "dappled light effect" or even the "venetian blind" somewhat overused look. A couple of 300W Arris are a must as they are a great backlight or background light and easy to hang! Rather than getting an Arri 150 perhaps consider the Dedolight...if you have a use for the projector. I don't know your normal situation but keep in mind an Arri Fresnel kinda sucks in a softbox...great for everything else.
Keep in mind that once you use a Dedo with Projector, you'll probably use it every day. It just allows so much control (20:1 spot ratio!!!) and that little something special that makes your work stand out. If I was travelling a lot I'd consider a Kino Flo Diva 400W universal or a Lowel Caselight (the Kino is fully dimmable tho)...as you can run 110-240 without changing bulbs or run daylight or tungsten. With the new Trumatch bulbs you get no green spike (stay away from Osram unless you plan to use a minusgreen gel). Well, my 2cents anyways, Brian Broz |
can I put an umbrella on one of thoes to make an omni light. and can I use them as tota and key professionally? |
Some Arri's are Fresnel lights so they cast a more or less focusable and strong light. People usually use them as a key. With a reflector, you could use the same light as a key and fill, if that's what you're asking. The open faced Arri's are broads that can light up a whole area. They would be the heavy duty equivalent of a Lowel Tota. You can't mount an umbrella onto these Arri's (there may be some out there that you can, I don't know). I don't like umbrella's anyway. They cast an uneven light. I much prefer softboxes. |
I'm pretty sure his "Omni" is referring to Omnidirectional, which means fill, Tota-Lights are often used as back lights too, so that might be the one there.
Yeah, nothing can really beat a set of Arris if you've got the cash, but I think you might want to look at more getting a really good softbox, a smaller light for back lighting, and then one arri for the key. If you want to do the typical 3-point lighting, then having 4 arris may not help you, if you don't quite know what to do with all of them. |
Other Options
This Altman kit is a good choice:
http://www.bhphotovideo.com/bnh/cont...goryNavigation As is this LTM Pepper kit, which I happen to own: http://www.bhphotovideo.com/bnh/cont...goryNavigation I picked mine up 2nd hand, barely used, by careful shopping around and reserching sellers, but it saved me $900 bucks. I'm not putting down Arri, but both Altman and LTM have been in this business for an awful long time and make fine sturdy products. |
Omni and Tota are the names of particular lights manufactured by Lowel. Please see their web-site for more info. http://www.lowel.com/index.html As a new to freelance shooter I only have a tiny light kit which consists of a Lowel Pro-Light for a backlight with barndoors and gel holder and a Lowel Rifa-lite 44 soft box for a key, cosmetic and diffusion gels, and two Home Depot dimmers. It has been adequate for my purposes, (working on a doc about a musician) but I would definately suggest a background light and another Rifa-lite (or similiar soft box type instrument) for cross lighting if you have a large area to cover. Always drooled over Arri's but can't afford them. Hope this is of some help, Stephanie |
If you're up for a bit of digging, you can find way cheaper alternatives.
http://www.dvinfo.net/conf/forumdisplay.php?f=41 |
