-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   Which litepanels Led 1X1 to shoot a Documentary about a mine in SPAIN? (https://www.dvinfo.net/forum/photon-management/488973-litepanels-led-1x1-shoot-documentary-about-mine-spain.html)
Marcus Martell December 15th, 2010 03:49 PM
Hi i'm about to shoot this documentary about the miners and this coal mine. I need LIGHT inside! I was thinking about the LITEPANELS 1X1. How many should i rent? for interviews i guess 2 or 3, what about the pits of the mines?
Litepanels offers many !x1 Led solutions, what should i get?
thx
Allan Black December 15th, 2010 05:33 PM
Hola! Depends on the theme of the doco Marcus, but just enough light for 2 coal dusted ppl .. leave what you can't see to the imagination.
Rent an LP (or 2 small ones to cross light) to try and turn the lights out. btw you won't see me down a freakin mine.
Cheers.
Caleb Reynolds December 24th, 2010 08:22 AM
I think 3 1x1's would be enough. I wouldn't worry about lighting the whole place up. I think it would be really cool if you didn't show the true size of the mine until the end. Keep everyone kinda guessing till the end. Make them want to see the whole mine first.
Charles Papert December 24th, 2010 11:51 AM
If you are inside the mine the whole time, your color temperature won't change so you won't need the Bicolor. Your most flexible unit will then be the Bifocus. I don't know what camera you are using and how big the mine is so there's not enough information to determine how many panels you would need to light up the mine. The 1x1's are good for interviews but not if you need punch or throw. If you must stick with LED's (power reasons), you can look at the new LP Sola. Good ol' tungsten would be a good bet, unless there are severe power issues in the mine. A 1K open face will give you a lot of output and spread, probably 3-4 times that of a Litepanel, which would be needed if there are large open areas in the mine. If it's all tight tunnels, then you may be OK with the LP's. A tunnel that runs straight for a couple of hundred feet would look great backlit from the end, but you will need some punch for the light to carry a distance. Remember that your eyes will adjust for the low light levels in there but the camera can only do what it is rated to do.
Marcus Martell December 26th, 2010 12:10 PM
Thank u all my friends.....
Any solution to power the LP 1x1 inside?
Charles Papert December 26th, 2010 12:13 PM
Inside...?
They can be powered via AC adaptor or from batteries, either outboard or mounted on the back.
