-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   Micro Softbox: is it for me? (https://www.dvinfo.net/forum/photon-management/48875-micro-softbox-me.html)
Konstantin Vilenchitz August 5th, 2005 01:12 PM
I have a pretty sparse set-up right now for my public access show, and that's the way I like it. :)
I want to buy things as I need them rather than travelling around with a lot of bulk since I'm a one man crew.
I use a Lowel Pro Light for lighting right now but I think the shadows it creates are a little harsh.
I'm shooting some interview footage to include as extras on a friend's DVD this coming Monday and am considering getting this Chimera Softbox.
Do you think it would be a good investment? If I have time I'll post some sample footage to give you an idea of how the lighting looks without it.
Thanks.
Konstantin Vilenchitz August 5th, 2005 04:35 PM
sample footage
OK I cut a short quicktime movie. This looks a LOT darker than the footage does on my preview monitor, but I guess that's just Quicktime for you.
You can still see what I mean about the shadows. They just look more dramatic here because the overall footage darkens as I export it from FCP.
Sample footage
If you can recommend any other lighting alternatives, I'm all ears.
Richard Veil August 5th, 2005 10:11 PM
HI some thoughts and Chimera DV film contest
http://www.studentfilmmakers.com/chi...g/awards.shtml
The micro is a good little run and gun bank. It is dedicated to the prolight with its hardware but you could adapt it for other on camera lights.
It is the on camera bank of choice of the eng world.
The bigger the light source the softer the light
Depending on what you plan to do you could buy something like the 8000 or 8005 kit
We make a speedring for the prolight that uses regular lightbanks and I have seen 12x16 videopros on camera.
If I can help drop a line and thats what I will try to do.
Konstantin Vilenchitz August 5th, 2005 11:41 PM
Thanks for the reply, Richard!
That 8000 kit looks impressive but it's over my budget for the moment.
"[The micro] is the on camera bank of choice of the eng world."
Sorry, what's the "eng" world?
The only things I really shoot in a controllable environment, where I can set up lights etc, are interviews. Usually one on one, and I like a nice tight shot. The 8000's description on B&H mentions it's ideal for "3/4-length interviews"...
Would using the 8000 kit be preferable to say two pro lights? I'm very new to lighting techniques so bare with me.
I'm mostly concerned with ease of set-up, and minimal load since I am carting everything myself, usually on the subways in NYC.
I've seen some Lowell light kits which seem attractive for around a similar price as the softbox kit. I guess I'm just not sure what the next step in lighting should be for me.
Richard Veil August 6th, 2005 12:57 AM
well it is all good
You could try a translusent umbrella for $20 off camera
ENG -Electronic news gathers
you could also try tough spun diffusion ect
shooting through trans fold up disk
banks are great too
Hope this helps
There is a cine show in NYC next month
http://www.nyces.org/pages/nyceshome.htm
Konstantin Vilenchitz August 6th, 2005 10:09 AM
What would be a good companion light for the Lowell pro light that I have?
Would an omni light be a good next step?
Would it be more logical to add another light first rather than to diffuse the prolight I use right now as a key?
Then make the omni the key and use the pro as fill?
Mike Cook August 7th, 2005 09:54 AM
I have one of these micro softboxes and really like it. The only problem with the Pro light is that is does not dim. I keep a few precut sheets of .3ND with me and clip them on the front to dim down when I need to.
Maybe our Chimera guy has a better suggestion on dimming the Pro light? Is there a simple gel holder for these micro banks?
Mike
Konstantin Vilenchitz August 7th, 2005 10:32 AM
Hey Mike,
Glad to hear you like the Micro softbox.
What kind of set up are you using the Micro for? What other lights are you using with it?
In terms of a dimmer for the prolight, I have one of these which could help you out.
Konstantin Vilenchitz August 9th, 2005 03:45 PM
Hey again, thanks for all the info.
After hemming and hawing for a long time, I decided to pick up the micro softbox yesterday for an interview I shot last night.
I was really pleased with the results! I was surprised at what a difference it made in the light quality from the pro light.
I'm eager to go over all the footage. It was incredbily easy to set up and I think it will treat me well while I set save up some for a larger set up like the Rifa.
