Lighting for greenscreen
Hey guys,
I've just opened up a magnificient studio and am offering to my clients small green screening services. Its just going to be a 12x24 screen and I am blessed with a very high ceiling. I'm looking on making a permanent light installation for quick shooting (mostly just people talking in front of a green screen). So I was thinking of rigging up a bar that can come up and down and from which I can suspend lights (kinda like a grid, but with just 1 bar). Now, he's the catch. I have a fairly good budget, so I need to find lights for this baby. I was thinking 2x 1k Fresnels (with diffusers or soft boxes) hanging from the ceiling to evenly light the green screen and smaller lights to light the subjects. I haven't shopped around for lights in a LONG time, so I'm looking for some help here. 1 - Are 2x1k lights enough you think? will they light evenly? If not, what would you recommend (I'm ready to spend between 2k$-5k$ for these lights) 2 - Can you recommend any good suppliers for lights? (I would undoubtedly need C-clamps to hang those suckers too) Oh and they have to be able to supply to Canada! :P I thank you all in advance! Jay |
Just to jump-start this thread a bit, if I remember correctly the main things
to achieve is uniform lighting and seperating your foreground from the back- ground. The first would suggest you need a row/bank of lights to flood the screen. The second would suggest you have some extra lights that kick from the back towards the front (at an angle) to illuminate the subject from the back (to seperate it). I've checked my lighting books and "Placing Shadows, second edition, Chuck B. Gloman & tom Letourneau" has this to say (on page 174): Quote:
- Most important thing about lighting the blue background is consistency in terms of evenness and color temperature - Don't use dimmers (color temperature shift) - Cyc strips are the easiest instruments to use (they produce an even wash of light) - If you fully need to key (ie, the floor also has blue/green material) don't light it straight down. A polarizing filter (on the camera) is highly recommended to remove glare from the floor - The ratio of light on the background screen to the foreground subject should be roughly 1 to 1 when measured with an incident light meter. That's about it I think... Hope this helps some |
Intresting and thanks.
As an editor i see quite some bluekeys, and the biggest (most frequent) problem is the light that bounces from the screen to the sides of the actor. Can this be completely countered by the use of sidelight? |
According to the book that is the primary function of that sidelight indeed.
However, I've never actually gotten to the point of shooting green/blue screen so I have no idea. I was merely quoting what the book says :) Hopefully some other people with experience will join in! |
Great!
Awesome answer!
The only thing I'm not quite sure about is : What are Cyc Stripes? Do you mean neon tubes? |
Frank,
In my experience, the biggest reason for green or blue light spill on the subject is that the subject is too close to to the screen. However, if you're working with painted cyc AND floor there's no way to avoid this. Side lights can work OK, as long as the lighting effect is consistant with lighting in the background composite. I've also seen backlights with colored gels (colored opposite the matte color) used with some success. Jason, here's an example of cyc lights: http://www.ultralightmfgco.com/sales...yc&state=sales Cheers, -Matt |
Well I took a look at the CYC lights and they look pretty affordable and good. I bet they're great at casting even lighting. now the only question I have left is : how many do I get? I have a 12x24 canvas. I was figuring maybe a 10 or 12 CYC light. But would that be overkill?
I've never worked with CYC lights. Are they easy to install? Anyone have experience with them? |
yeah a pink filter on your back/side light can help if you can get away with it (keep it off the greescreen though.) maybe like a 1/4 minus green (for color correcting fluorescents) would kill the green spill without reading too pink.
Having done quite a bit of blue and greenscreen work I personally would AVOID using cyc lights for this kind of work. (I have lots of them.) WHY? Because each light produces a HOT SPOT. What that means is that the camera will see a GRADATION formed out of each light. Diffusion will help, BUT not completely, and it wears out. Tungsten lights also produce lots of HEAT and draw a lot of power. If you have a budget, look into florescent lighting which draws less power, runs cooler and provides much smoother light. |
Any advice on where I could get them ? (website?)
b&h has plenty-
http://www.bhphotovideo.com/bnh/cont...ren&Q=&ci=1167 i've not used them for international shipping before, but i'm sure they can take care of you. the upcoming arri stuff looks really nice. |
Great site and the fluorescents make sense since that is what I used last time I shot greenscreen in Toronto.
Now from what I gather, I should use a NON dimming fluorescent. I also figure a 220 WATT lamp should be powerful enough to light my 12x24 matte. I of course need a hanging mount. And probably some eggcrates to diffuse the light a bit. Now here is the question, which one should I get? hehe The Arri Studio Cool 4? A Desisti 4 Tube? A Lowel-E Studio 6 with a 40 degree honeycomb grid Or simply Kino Flos? Oh and for greenscreening, should I use a 5600 Kelvin light (daylight)? or another type of tube? Man I have alot of questions :p Cheers! |
They are a lot cheaper. It is rare that you need a screen dimmed in my experience . . . as in I've never needed less light. >>>I also figure a 220 WATT lamp should be powerful enough to light my 12x24 matte. One? I would think you would need/want as many as you can line up end to end. Remember, you want to somewhat match the exposure of both talent and screen. IOW, a brightly lighted person and a dimly lighted screen will not give you 'effortless' results. >>>I of course need a hanging mount. And probably some eggcrates to >>>diffuse the light a bit. Yes, you'll want to hang them, but most lights come with at least a yoke so you can use inexpensive pipe clamps. I get mine from www.proadv.com I don't think you *need* egg crates. First, they are EXPENSIVE and are generally used to control (read: focus) soft light from spilling all over the place. As long as the screen lights don't directly spill heavily on your subject (and they should NOT unless you messed it up) you won't need egg crates. >>>Now here is the question, which one should I get? hehe The Arri Studio Cool 4? A Desisti 4 Tube? A Lowel-E Studio 6 with a 40 degree honeycomb grid Or simply Kino Flos? All of the above are good choices. I don't think you can go wrong with any of the above. >>>Oh and for greenscreening, should I use a 5600 Kelvin light (daylight)? >>>or another type of tube? Is your screen painted blue (or green) or is it white? Not that it matters that much because what you want is simply smooth lighting. Good software will pull the key from almost color you select. Higher color temp light will produce a different (resulting) color on any background than 3200K, but most keyers don't mind. You usually 'tell' them the color to use. >>>Man I have alot of questions :p Keep 'em coming. That's what this forum is all about :) |
Don't use dimmers?
Interesting that people say dont use dimmers, because the reality in big budget "green screen" films is quite the opposite...
Last month i prepped sixty 32amp hp12 dimmers for just one sound stage on superman returns. Green screen Movies like matrix, stealth, superman returns are also using huge banks of ordinary rock'n roll PAR cans with halogen bulbs & large silks in front. The Matrix sequels used over 2,500 par cans [1000w]. With studio setups it pays to use dimmer systems with dmx control from a lighting desk, even for cyc's and fluro's. I would recommend you have 3 truss runs. One in front of the talent with a light on either side of center, one truss behind the talent with light on either side of center, and one lighting truss above the green screen with 3 lights to light the screen. Run all cable from lights to the one side and then run it upstage to a 12 channel dimmer[$500-1000]. With your basic & every easy to use 12 channel lighting desk[$100-200] you can grap a coffee and sit down & relax. Each channel on the desk controls one light, so creating the key, fill & back light loooks is easy. The dimmmer and desk do all the leg work for you. The cheapest option for your lights is to buy second hand quality theatre fixture [fresnals] they will come with clamps to hang off bars. Theatre lights are designed to be used in studios & for the light to be controlable. Expect to pay around $100 - $ 300each for 1000w fresnals. On a sidenote, have you checked what the power supply situation is? |
Just a note about this incredible forum and the incredible people who post. We would have had to pay a fortune in film/video school to obtain the knowledge that Shane just shared with us for free.
Thank you SO MUCH Shane. Just such amazingly helpful information and so kind of you to take the time to share it with the rest of us. Many, many "miracles" coming to you soon friend. Just try and recognize them as such. All the best, Stephanie |
Thanks for that Shane! Always nice to hear from someone who has actual
experience with this kind of stuff. Perhaps the book was not talkig about dimmers that are made for this but more like the home depot onces? I don't know. |
[QUOTE=Shane Matich]Interesting that people say dont use dimmers, because the reality in big budget "green screen" films is quite the opposite...>>>
A slight misconception here. I did not say not to use dimmers on instruments for lighting the *screen*. What I said was that dimmers (especially those 'on board' a florescent instrument) add to the cost . . . significantly. The experience you relate is that of a BIG Company who paid for TONS of lights and dimmers. Why not, if they have SUPERMAN as a client? The questioner was concerned if *he would need "on board" dimmers an instrument or two*. That answer would be no. He will need those few lights up full. Yes, dimming is nice, but when you only have a 1 or 2 lights with which to light the screen, you need to invest in MORE lights first. <<Last month i prepped sixty 32amp hp12 dimmers for just one sound stage on superman returns. Green screen Movies like matrix, stealth, superman returns are also using huge banks of ordinary rock'n roll PAR cans with halogen bulbs & large silks in front. The Matrix sequels used over 2,500 par cans [1000w].>> From what you state here, it seems obvious he will need more instruments than 1 or 2. In addition, depending on over all power draw, a 32 amp dimmer is TINY. 32 AMPS is will only power 4 1000W lamps at full power and you usually try not to run a dimming channel at max load. <<<With studio setups it pays to use dimmer systems with dmx control from a lighting desk, even for cyc's and fluro's. I would recommend you have 3 truss runs. One in front of the talent with a light on either side of center, one truss behind the talent with light on either side of center, and one lighting truss above the green screen with 3 lights to light the screen.>>> I prefer stand lights for the front and side lighting. Trusses mean you can not adjust the light angle unless you have a way to lower and raise the truss. 3 lights for a 12'Hx24'W screen will not really be enough in my experience. High angle lighting on the actors also produces many shadows on the floor . . . not good. <<Run all cable from lights to the one side and then run it upstage to a 12 channel dimmer[$500-1000].>> Can you give us a website that sells a 'real' 12 channel dimmer for $500? I think a Leprechon 12 channel dimmer @ 2.4Kw per channel lists for over $3K! After that, you will still need feeder cable, camlok connectors etc. It all adds up to lots of $$$. Heck, even a single channel Stand dimmer @ 2.4Kw costs $1,000 at B&H <<With your basic & every easy to use 12 channel lighting desk[$100-200] you can grap a coffee and sit down & relax. Each channel on the desk controls one light, so creating the key, fill & back light loooks is easy. The dimmer and desk do all the leg work for you.>>> Hmmmm. From my experience, nothing is ever easy, especially if you go to the next level and try to match the character lighting (green screen) with the back ground scene he will be composited on top of. That said, YES, if you can, you should buy dimming. No doubt! <<<The cheapest option for your lights is to buy second hand quality theatre fixture [fresnals] they will come with clamps to hang off bars. Theatre lights are designed to be used in studios & for the light to be controllable. Expect to pay around $100 - $ 300each for 1000w fresnals.>>> You can buy a BRAND NEW 1K Altman fresnel for around $300 at B&H. http://www.bhphotovideo.com/bnh/cont...ughType=search But, I don't recommend fresnels as a first choice for green screen work. To much hot spotting as I said before. Florescents are smoother and produce less heat with MORE light given the same wattage. |
Like Stephanie said, this is a very helpful thread, and it's great to hear the perspective of both the big studio and the less expensive setup.
| All times are GMT -6. The time now is 01:08 PM. |
