Inexpensive Lowell Lighting for Interview Shoot?
Hi all,
I have a gig next month where instead of renting lighting I'm going to try and buy some very inexpensive lights, such as the Lowells recommended by Guy Cochran: Quote:
I have 2 mic stands that I should be able to clamp those on to. Also, I saw this video about a $7 flex fill, any thoughts? http://revver.com/video/435831/poor-mans-flex-fill Does that mean that theoretically I can get away with 1 Lowell light, the inexpensive flexfill substitute and the tungsten back light? Is the tungsten even necessary, and if so what would you recommend? Here are a couple examples of the kind of videos I'll be shooting: http://www.youtube.com/watch?v=Xsq6UdpqPII http://www.youtube.com/watch?v=rdtpYnVbYN8 Thanks! |
I'm all for doing lighting on the cheap, and I certainly have some of these flood lamps. But honestly, you'd be better off going with a small kit. The more you can control the environment you shoot in, the less lights you will need. If you cannot control where you will be shooting, the more lights (and grip) you'll need.
I've done lighting setups with 2 stands, 1 light, and a piece of foamcore. Not the easiest way to shoot, but it works if you have strict control. I would advise you to be careful with using silver shinyboard. Get it wrong and you'll blind the talent. And they will NOT be happy. I prefer using a butterfly to soften the direct sunlight, than trying to fill on the side away from the sun. And the talent is always appreciative of you taking them out of the direct sun. |
Hi Perrone,
Thanks for the tip, but I really can't afford to buy a kit right now. I think I'll buy 2 Lowells, the flood reflectors and maybe a tungsten for the back. How necessary is the tungsten backlight? And if I have to get one, should I get a desk lamp like Guy mentioned, or will the tungsten work with another flood reflector? This shoot will be indoors at a hotel, so it should be fine, but I will want to have these lights to make sure everything goes well. I think it will be pretty much like the example videos I posted, but I want to make the lighting better than what's in those videos. |
