-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   Suggestions for a softbox required? (https://www.dvinfo.net/forum/photon-management/22014-suggestions-softbox-required.html)
Aaron Koolen February 26th, 2004 03:01 PM
Hi guys. As mentioned in another thread I'm going to be doing some interviews in a few weeks. Want to chuck a Fresnel into a softbox for key but was wondering what you'd all suggest as a good size. I've been suggested the Chimera Daylight Junior Plus but that's a whopping 90cm x 120cm! Sounds rather massive to me. Would lighting people require something this large? It will be mainly medium->close shots.
Cheers
Aaron
Kris Carrillo February 26th, 2004 05:30 PM
Keep in mind: The larger the source, the softer the shadow. If you want a really soft key, then it would make sense to get a larger chimera. I use a medium Photoflex Silverdome for interviews which is around 24" by 36". Also, the the distance between the subject and the softbox will change the relative size of the source as well. Good luck,
Kris
WCTV 56
Jeff Patnaude February 27th, 2004 09:58 AM
I work for a corporate production house, and we have the Chimera Video Pro banks. I think they are about the same- 24" by 36". They work great. Very versatile.
You didn't mention what size the Fresnel light was however. Depending how loose you are shooting, you could get away with a white card for fill and a small backlight.
Jeff Patnaude
Barry Schmetter February 27th, 2004 02:56 PM
I have a Photoflex Silverdome that's the same size (3 X 4 feet). Although a little unwieldy in a tight space, it's a great size and very useful for close-medium shots. As mentioned, the larger the source, the softer the light. You can make the light from a large softbox harder by moving it further from the subject or removing the diffusion baffle. A larger box will also do much better covering a 2-shot.
Barry S.
Aaron Koolen February 27th, 2004 05:57 PM
Jeff, sorry. I was thinking of using something like an Arri 650W fresnel as my standard key for now.
Cheers
Aaro
Jeff Patnaude February 27th, 2004 08:13 PM
Aron,
might not look bad to use a little opal diffusion on the 650 for a key light, and a bounce card for fill. The opal will soften the light a little, causing it to wrap around a little.
You can place the 650 at an upwards angle into a 4x4 piece of foamcore for a key light, and a reflector for fill. Experiment.
Good luck to you.
Jeff
Bryan Beasleigh February 28th, 2004 10:41 AM
Photflex makes a Cinedome which has a longer throat , designed specifically for fresnels.
To quote the site "The Cinedome has a narrower, deeper profile designed to maximize the light projection of your Fresnel lights."
http://www.photoflex.com/photoflex/index.html
click on "products"
on "Softboxes for hot lights"
then on "CineDome"
The CineDome will maximize the lighting with a fresnel yet be entirely usable with any standard fixture as well. The SilverDome won't as the light beam will bypass the reflective walls for the most part.
I don't think there's much difference in the cost.
Barry Schmetter February 28th, 2004 11:58 PM
I have a Cinedome as well as the Silverdome and the difference in light quality is very small. This is with an Arri 650 although I tend to use a Tota-750 in the soft banks. The Cinedome is much bulkier and generally a bigger pain in interiors. The Arri 650 in the Silverdome is plenty soft, even with the internal baffle removed.
Barry S.
Bryan Beasleigh February 29th, 2004 02:39 PM
I agree with Barry. You can even buy an HIR650 bulb that will give the equivilent light of a 1000 watt lamp. It costs about 50% more but draws a lot less
