-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   Diffusing some el cheapo lighting (https://www.dvinfo.net/forum/photon-management/10089-diffusing-some-el-cheapo-lighting.html)
John Lee May 25th, 2003 10:15 PM
I got a pair of 500W halogen bulbs, work lights I believe, and they provide excellent lighting considering I only spent $20 on them. However, I've had to bounce them off the ceilings and walls because they're way too bright to shine on anyone's face. I was wondering where I could purchase some sort of translucent white material to clip on in front of the bulbs, so that I could point them straight ahead. I would just clip a piece of paper in front of them, but obviously they get way too hot to do that. I'm just looking for something white and translucent to help soften and diffuse the light, that I can easily clip on. Any suggestions?
Bryan Beasleigh May 25th, 2003 10:22 PM
http://www.leefiltersusa.com/PDFs/Li...PdfIndex.html#
Here's a link to some literature about diffusion material. You could always lamp down. (put a lesser wattage bulb in)
Alex Knappenberger May 25th, 2003 10:27 PM
You are best off building a softbox, or bouncing them, like you said, check out this article:
http://dv.com/features/features_item...1/bjohnson0401
Adrian Douglas May 26th, 2003 10:45 AM
Mate go to the supermarket and get yourself some ovenproof baking paper. Remove the wire cages from the front of the lights and wrap them in the paper, a couple of layers should do the job, make sure you fill in the holes on the sides. Put the cages back on and your in business.
K. Forman May 26th, 2003 10:51 AM
Uh... I would disagree with Adrian- Do not remove the cages. They are there to keep you safe in case the bulb blows. As far as wrapping them with wax paper, just make sure you leave some room for them to breath. Wax paper will indeed make a good diffuser. Also, you might consider using umbrella reflectors. They make the light much broader and softer.
Bryan Beasleigh May 26th, 2003 11:20 AM
Adrian is speaking about bakers parchment, not waxed paper. Baking parchment can withstand a 450 degree oven without browning.It's also known as silicon paper. Comes in a wide roll for under $4.
I would also agree that it would be bad practice to remove the safety screens.
K. Forman May 26th, 2003 12:35 PM
My mistake, I meant the same thing <G>
Dylan Couper May 26th, 2003 01:39 PM
Adrian does say in his post that you have to put the cages back on.
I think Keith has a really good idea with the umbrellas. They are cheap and much more versitile than diffusion paper. I've seen them as cheap as $10-$20 on Ebay. Should be easy to clamp them to your light stands with about $3 of Home Depot parts.
K. Forman May 26th, 2003 02:30 PM
I got a pair of umbrellas off ebay for about $10 ea. And I must of missed where Adrian said to put the cages back... My bad :)
Bryan Beasleigh May 26th, 2003 04:44 PM
I know the idea is to save money and not spend it, but a lobo clamp or D200 grip head would really make things easier. the d200's are around 420 ans a lobo (wescott or lowel) around $25.
http://www.bhphotovideo.com/bh2.sph/...ID=F59DBA14190
The lobo will clamp an umbrella to almost anything.
Adrian Douglas May 27th, 2003 05:35 AM
Thanks Dylan. Yes, don't leave the cages off, that would defeat the point of wrapping them in the baking paper, as well as create a safety issue.
As Bryan pointed out don't use the waxed stuff. I've used the baking paper on the same lights and it does a good job if you are totally strapped for cash. One problem with these lights is that the colour temp is very low, about 2800°K and result in a very warm light. It look nice if it is your only light source but it dosen't mix well with daylight. To correct this some blue gels clipped on to reshaped wire coat hangers will help cool the light a little.
Dylan Couper May 27th, 2003 09:17 AM
Any particular blue gel you can reccomend?
Adrian Douglas May 27th, 2003 10:49 AM
Lee are very good but expensive and only come in roll or large sheets. I used to get off cuts from a friend back in Australia who did stage lighting for bands but here in Japan gels are hard to get.
Do a search on Google and you should find some good stuff.
Wayne Orr May 27th, 2003 11:29 AM
Here is a link to Lee Filters available at Film Tools in Burbank, CA. You will see that a single sheet, which is all you need, is about $5.50. I recommend you use the 216 diffusion. You can also get "blue frost" for a diffusion with blue correction built in. http://store.yahoo.com/cinemasupplies/leedifsheetx.html
BTW, those wire frames around the lights are for keeping fingers out and other materials from touching the globe. They will provide very little protection if a globe pops, sending small pieces of hot glass flying, so be careful with those lights.
K. Forman May 27th, 2003 01:07 PM
Every little bit helps. Safety first.
Dylan Couper May 27th, 2003 02:17 PM
Wayne, good link.
As far as the bulbs blowing in shop lights, most units I've seen have sheets of glass covering the bulb. I'd consider it a very important safety factor if you are shopping around for a set of these lights.
Bryan Beasleigh May 27th, 2003 08:00 PM
The safety glass has to be for the light to be UL CUL or CSA approved. Not a good idea to be removing safety shields. Apart from personal injury the hot glass will perminently scar a carpet or upholstery.
Adam VanScoyoc June 3rd, 2003 08:56 PM
blue gel
Ok, since you guys mentioned blue gel,
Let's say a couple cheap 500w halogen shop lights are the extent of my lighting arsenal. If I wanted to create a blue light to simulate moonlight in a fog filled horror movie, could I get away with blue gell in front of one of the shop lights? I'm not talking about blue gel to correct the warm color of halogen, I mean an actual blue light. What would be the most practical way to achieve this? (and least expensive)
Adam
Adrian Douglas June 3rd, 2003 10:35 PM
Gels come in various grades from colour temp adjustment to changing the colour of the light. Do a search on Google for a distributor near you and check out what they have.
Bryan Beasleigh June 3rd, 2003 10:45 PM
Look at the link that i posted on the first part of this thread. it was for the Lee filter PDF catalogs for there line of lighting gels.
