Variable Frame Rates
Sorry, I did not want to bother you, but couldn't find isntructions, so can someone tell me workflow to achieve flow motion with HVX200
To achieve Flow Motion...
You have to be a really great cinematographer... with a mind for surreal mix of fact and fantasy. |
I specially liked the super slowmo demo. Most likely film at 120fps If Levan was asking about slow motion with HVX then. Set camera menu 1 to film camera-frame rate from 12 - 60 fps Make sure that you are 720. If you are using a P2 card use the PN mode. For slow motion at 720/24p at what ever the frame rate you choose over 24. For fast motion 720/60p and any frame rate below 60 fps. |
