-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   Questions for the DVX200 gurus (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/89839-questions-dvx200-gurus.html)
TingSern Wong March 24th, 2007 08:10 PM
Questions for the HVX202 gurus
Hi - I am sorry ... title should be "HVX202", not DVX200 :-).
After using the camera for about 1 week - have a couple of observations / questions.
1. In manual exposure mode, how do I judge whether the exposure is okay? There is no indication of under/over in the viewfinder. Over - I can see if I turn on Zebra. But, under? I am used to seeing Canon XL2 camera meter. Went hunting through manual but, I fail to see it. Am I missing something here?
2. Sound recording - in the manual, they indicate like this -
ch1 ........|.....|..........|
ch2 ........|.....|..........|
But what I see in the viewfinder is this -
ch1 ........|.....|
ch2 ........|.....|
Basically the 0VU indicator is not there. Is this a fault of my camera or everybody else? If everybody else is lacking the 0VU indicator, how to tell whether sound is reaching 0VU or not? Note that ATC is turned ON.
3. Scene Files -
Oh ... changing and/or setting these files is a pain using the camera. Does anybody knows of a Windows based program to set this up in the SD card and then just insert the updated SD card into the camera?
TS
Andzei Matsukevits March 26th, 2007 11:29 PM
3. scene files are in .txt format. You just need wordpad for editing them.
TingSern Wong March 27th, 2007 12:27 AM
Thank you. I will go back and try it tonight then.
Phil Hover March 27th, 2007 01:00 AM
1 . switch to the marker mode by hitting zebra until you get the square in the middle of the frame - point it at an area and it will give you a percentage of exposure from 0 to 99. Anything 15 or lower is getting under exposed.
2. The audio meters will hit in red when you are approaching the 0db mark. Yell into the mic and you will see it on your lcd. They normally dont show.
3. just use notepad.
TingSern Wong March 27th, 2007 09:49 AM
Perhaps I share my experience editing the scene files.
A typical entry looks like this -
<F1>
SCENE NAME :NORMAL
00005000: 8 ; DETAIL LEVEL: 0
00005001: 8 ; V DETAIL LEVEL: 0
00005002: 8 ; DETAIL CORING : 0
00005003: 8 ; CHROMA LEVEL: 0
00005004: 8 ; CHROMA PHASE: 0
00005005: 8 ; COLOR TEMP: 0
00005006: 16 ; MASTER PED: 0
00005007: 8 ; A.IRIS LEVEL: 0
00005008: 1 ; NEWS GAMMA: OFF
00005009: 0 ; GAMMA : HD NORM
0000500A: 0 ; KNEE: AUTO
0000500B: 0 ; MATRIX: NORM1
0000500C: 1 ; SKIN TONE DTL : OFF
0000500D: 0 ; V DETAIL FREQ : THIN
0000500E: 0 ; OPERATION TYPE: VIDEO CAM
0000500F: 0 ; FRAME RATE: DEFAULT
00005010: 4A026801 ; SYNCRO SCAN :
The important part is NOT the words like "News Gamma: OFF" ... but the HEXADECIMAL number before the semi-colon. Some are binary fields - 0 means ON, 1 means OFF. Others are the actual values - typically 8 being 0, 7 being -1, 9 being +1, etc.
Figuring those out took me about 30 minutes ... wondering why the camera didn't like the numbers ...
