Does the Panasonic BT-LH900 HD monitor do image flip?
Hi all. . .
I've pretty much decided to go all out on my monitor and buy this one, but I need to know if it REALLY does the 180 degree image flip function to use with my M2. I've heard nothing but good things about this (truly ridiculously expensive gizmo), but I sure as heck am not going to buy it if I can't use with my Redrock! Any thoughts? Thanks much. Stephen |
Unfortunately it does not "flip" the image electronically, however it does have mount points on both top and bottom of the outer case so you could simply mount it upside down and achieve your desired result.
Keep in mind that when you turn the unit upside down all the menus and the WFM will also be "flipped", so you'll have to get used to reading your information that way. |
| All times are GMT -6. The time now is 07:55 PM. |
