-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   Firestore DD won't enable-fails (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/79284-firestore-dd-wont-enable-fails.html)
Michael Mills November 9th, 2006 11:24 PM
Both of my PCs are having fits with the Firestore. I used to be able to move footage off the Firestore to a HDD. Now, when I plug in the firewire cable the XP OS detects it as a Panasonic DV Camera and installs a driver. When I go to DD and Enable, it fails. The DV Camera driver seems to be causing the FS-100 to fail to connect with the computer. I've disabled and uninstalled the Panasonic DV Camera driver and it continually returns upon detection of the FS-100.
I've email Focus about the issue. They weren't helpful with a resolve.
Has anyone had this problem and know a workaround or fix within the XP OS?
Thanks for your help!!:)
Michael
Mike Schrengohst November 10th, 2006 07:59 AM
Try with USB cable...
And or, piggyback it through another
already connected HD to see if you
can fool the computer.
